D
Deleted member 4210
Guest
Unless I'm missing something, there appears to be a dearth of folding ebikes that have more standard size 20" tires that aren't fat (I.e. 4" thick), that are reasonably priced (I.e. below $1500). There are however all kinds of fat tire folders. They're all very heavy, and impractical to fold.
I'd like to see a folder that has 2" thick tires, low step thru, front suspension, 14ah battery, with integrated lights, fenders, throttle and a 350 watt hub motor and 36 volts. (500 watts and 48 volts is ok, but largely not needed for the crowd who are looking for folders that they can actually lift.) It should not weigh more than 45 lbs. Priced at less than $1500, and preferably around $1200.
Many folders weigh close to 60lbs, usually have fat tires, and are just plain clunky. Folders that one might consider svelte, often cost over $3000 and usually don't have front suspension or other important features that consumers request. Even 50lbs is not 'svelte', when it comes to 'folding' and lifting into a car, or hauling up some flights of stairs, and rigid front fork on tires that are only 1.75" wide, and 20" rims (very stiff), are not going to be comfortable for more than a few miles.
I get asked for the type of folder and characteristics I've described, fairly frequently, and those customers often end up settling for a compromise.
This seems very doable. Any OEM's willing to step up ?
