Got mine this afternoon around 3:30. Had to meet the driver 10 minutes away as my place isn't semi friendly as I live at the end of the road. It looked lonely in the 28' semi all by itself. Box was undamaged so I signed and threw it in my wagon.
Got it out of the box without straining my back which is a positive. Packaged well enough as reported by others. All parts included. Mine is a medium btw.
Pulled off the rear wheel for tubelessing and then set up the handlebars for my preference. From right to left:
Grip Shift shorty grip
SRAM 12spd Grip Shift
Throttle
Brake mount
Stem with ugly to big display that I don't see any way to make less obtrusive so thinking an eggrider is in the cards.
Mode control pad
Brake mount
Dropper lever
WTB grip
Handlebars are way wider than my old school ones I've been using. Guess I'll get used to them as they seem to be the thing these days.
Took off the Rekons/tubes, what is with the schrader valves?s/rim strips then massaged the spokes to see if there was any looseness. None and in fact felt good and both were super true with no hops. Bonus! I had some MucOff 35mm tape and put that on (highly recommend btw) and luckily the valves I got had extra big grommets and seem to be holding well in the oversize hole.
Mounted my preferred WTB tires, 2.6 Vigilante in the front and 2.8 Vigilante in the rear and they seated right away with my little harbor freight compressor. Hypo'd in 120oz of Trucker Cream, aired up to 25psi and did the rotate and shake thing and they are holding just fine. I'll leave them overnight but will most likely be using more like 15 or so psi as I have with my other emtb.
Life got in the way for awhile and then I put the wheels back on and went over all the nuts and bolts and adjusted the bar population and tightened all that down. I have a small USB light and while it would turn on, which excited me, it didn't work for more than a few seconds plugged into the back of the display. There is a street lamp, the only one for a mile in any direction across the road and I headed for that but I only got one down and up in 1 mode, of 5, before it went to bed for the night.
No blemishes in the sparkly paint nor carbon fiber lay up issues but the white LUNA logos on the DT are ugly as sin
would much prefer if they were the black like the X2 has.
The no name rear hub engagement is very sloppy and a probable cause for why people are breaking chains. I am used to a Chris King hub. That will be changed. The crank engagement is a bit sloppy also and those two working against each other is another chain popping problem I suppose. The throttle is not programmed right either and I will not be offering test rides until that is calmed down a bit...likes to jack rabbit off the start which is the main reason I like a throttle. I am getting a programming cable and have links to all the softwares so that can at least be fixed. PAS seemed to work ok other than the drive train lag and the motor I would say is pretty darn quiet for a steel gear motor.
Overall I am happy enough with how things are turning out but if it is only good for 20 miles of ride time it will be up for sale.....Oh, and there are absolutely no issues with chain line or hitting the chainstay in the lowest gear. Must be because it doesn't have the special Hydra rear end that was developed in house and LUNA forgot to rip that part off, which supposedly was the special part to begin with.....oh the drama
