scott jewell
I am looking to build my own battery but know little about LIFEPO4 cells.
I do see that they sell a lot of cells for a reasonable price. I had three 22 Ah SLAs but were VERY heavy and weighed the bike down.
I also found out that people like to run the cells in series and use a BMS. I do not want any BMS and running cells in series the pack is only as good as the weakest cell. NOT what I want.
For one thing I almost got run over by a city bus when I started across a busy intersection the light was green and then turned red. My pedal chain was broke and the light turned red and the 36 volt controller had an LVC
or low voltage cut off which happened in the center of traffic. I came within inches of dying that day.
I changed controllers but heard that a BMS has the same feature. Therefore I want to run ten packs of ten in parallel. I was told that these batteries are only 1/3 what they are rated for. That is false advertising which should be considered a crime or a scam.
However I do not wish to order LiPo as a fire hazard. My cousin almost burned his house down with one of those self balancing skateboards. Therefore LIFEPO4 cells are my last hope as do not have $500 or more for a factory 20Ah LIFEPO4 pack.
Please someone let me know if the following diagrams will work and reccomend a charger for that please.
