Order #4008 arrived yesterday.
Controller locked.
Paint chipping off next to folding latch with ugly bend like someone hit it with hammer. Rest of the bike looks good except the screen which I think is ugly.
Break pads were touching the rotors so I had to make little adjustment and they are perfect now. Cleaned them too and they are as quite as they can be.
Rear derailleur didn't shift to 1st and 2nd gear. Removed the guard and it still didn't shift so I had to adjust it. 30 min and it shifts perfect but there was another problem. Chain was rubbing against derailleur rail , I think that's how you call it , so I had to bend it a little to make clearance for chain . Worked great and everything is working as it should now.
After that I installed new handlebar grips , left mirror , switch for car horn
, phone holder , suspension seat post , put 22 psi of air in tires and charged the battery. I also set pas sensitivity to 1 and pas strength to 5 (P11 and P12)
By then it was after 10pm so no fun ride but I did little testing today.
10 miles on odometer with mix of every pas level and throttle took 1 battery bar (not bad).
Seat got to go. Even with suspension post it is bad on bumpy road.
Tires are very noisy and I be changing them to Kenda road tires.
Screen is ugly , I would like it if it was in horizontal position.
Now little on technical side.
Speed won't increase even if you disconnect speed sensor wire (tried throttle only) , it also disconnects speedometer.
Controller is 6 FET only , with no brand name on it , just printed sticker with basic info.
It limits power at 18A so normal current around 11A. ( I think this limits the speed but don't take my word for it ) .
It is around 100mm long and you can fit bigger in frame no problem.
Someone asked if I ordered color screen and the answer is yes. I ordered KT LCD8H screen but if you want this screen you will need new controller too. Original controller won't pair with this screen.
That's it for now , will try uploading some pics tomorrow.
