Taylor57
Fair enoughLook up "Condescending".
Mike,Each of the two bikes we purchased (one standard and one step thru) had one bent brake disc (one front and one rear). I could not get the rear one to not drag on the brakes no matter what I tried (adjusting cable, adjusting pad carrier and trying to straighten/bend rotor). I will look into the tool previously mentioned and may need to remove the disc entirely to straighten it accurately.
-Mike
YEs I have a slight wobble... spokes are probably not trued and the fat tire is probably not perfect either.. Lower the pressure and ride it.. Once you have a few miles and everything settles then adjust the spokes and true the balance of the tire if needed..It doesnt bother me and like has been said... When you spend $10k I think I would have a comlaint or 2... I spent $800 so it was a throw away bike for me but it actually turned out to be a lot of fun. I have the original version and I have about 600 miles on it now..
mag wheels are the lowest quality wheels and will never least and your stuck with the junk hub them come with. there is a reason you only see them on cheap bikes.I'd like to see a couple of changes (or options) offered on these bikes that would improve the ride quality and reduce maintenance substantially...yet not cost any more. 1) Spoke-less MAG type wheels (see Jeremiah McIntosh'es latest fat tire eBike review). This would eliminate any possible wobble issue due to spokes, and also eliminate flat tires due to those metal spokes poking through the rim tape. 2) Offer tires that are not nobbies, but more of a hybrid like the RAD Power 4" KRAZE tires which fit the Lectric version 1 ebikes. The ride is much quieter, and yet have enough bite to go in the dirt or grass. These seem like little things but would make a huge difference.
