Corporall Clegg
- USA
Scott,Mr. Craig,
Add me to the list of happy owners with the same condition. It does NOT effect the way it operates at all. I also changed to a 11-28 freewheel. Well worth the effort. Lectric chose not to use that for what ever reason but that is what it came with. It is not a defect. I'm sure any competent mechanic, you or me included, can repair a slightly wobbly brake rotor. A lot easier then trying to send it back
My 2 cents, It is what it is. It was not made by Starrett and does not need to be. It is a very fun and useful toy sold at a reasonable price. I can fit two of them in a Honda HR-V plus luggage.
May I suggest we all temper out expectations and go out and enjoy the ride.
Scott
I will add you to the list of defective Lectric product owners and accept your statement that your Lectric ebike is not operationally affected. My Lectric ebike, is operationally affected. The issue with both of our units and most likely many others regards rear wheel wobble, this defect in my case translates to rider vibration, the cause of this vibration is not a brake rotor, it is a poorly machined motor hub threading. The rotor itself could not present that type of symptom on this platform when the brake is not in use. Yes, truing a bike rotor is easy but the least of my concerns nor will it have any effect on the issue of vibration felt by the rider due to freewheel wobble. To the best of my knowledge improperly machined hub threads cannot be repaired. I would be interested to know how one would approach re-threading a wheel hub without removing more material than a replacement freewheel would be able to re-engage with when reassembled. You also mentioned you have the same issue and you replaced the freewheel, that would further confirm the wobble was not addressed by its replacement.
As far as your opinion on the Lectric XP ebike, that’s great, I am glad that you settled for its condition and it works for you. As for myself, I purchased this unit due to the rave reviews regarding customer service, being the other options are direct from China and have no middle man to offer service. Lectric has not only failed to provide customer service to me, they are currently willfully violating the legal terms of their warranty, that fact seems to be lost in translation here in these forums.
Let me simplify my experience with Lectric:
Lectric provided me with a defective product.
Lectric is aware of said defect and claims it is their standard therefore negates it then offers the kindly gesture to send back said defective product at a loss to the customer of a third of the product cost.
The questions I have are:
Do you consider this scenario an example of quality customer service?
Are you suggesting I should ignore the above documented defects as well as the company’s response to them and then praise them for their actions?
