Yes, that is my CCS in a crop of an image snapped today.
So, the =thought= of the guide ring is that the gap should be narrower than the chain is wide. But it is wider than the chain is wide. So the darned chain falls outboard and slides slick as can be and you windmill and feel like you've been fooled again.
When I put on the narrow-wide, at that same time I put on the Shimano Shadow Plus derailleur and XT shifter and 10S 11-42T cassette.
I cannot say that the chainring by itself will be the full cure. But do some reading and I think you will find that most folks find a narrow wide ring provides all the fix they really need.
Here are some very good and easy to use chainring bolts, with hex wrench holes on both sides. So much nicer than the stock chainring bolts (which must be replaced, anyway, if you ditch the useless guard ring, because they will be too long).
*Sigh,* that the guard ring only protects pants...
