Reid
Most of my runs are well-under the standard CCS's 48V battery pack capacity. I am good with the standard size battery. Sure, it would be great and I would pay for the largest, highest-volt battery pack someday. But it is not needed at present.
If I had it to do over again I would still order the bike with the standard battery. It is cheaper and it is lighter and it is simpler and it is more robust (super-capacity upgraded cells may not last so long at 20A drain rates).
The point is that those who really need extra range can economically get it with a non-Juiced, external pack wired in parallel. And if I understand correctly, if you were to elect to get a higher voltage pack, like a 52 volt brick to put with a 48V stock CCS battery, use a diode in series so the 52V can't feed into the 48V pack. Not ideal, but it would work. EEs here, please correct me.
