Jason Knight
- USA
- City
- Keene, NH
That might explain why this past spring when I did a fork and rotor swap, my brakes stopped working right after flipping the bike over for an hour, and why when I flushed the rear line there was bacterial growth in the system with me thinking "how did enough water get in there for this to happen?"Stefan, I have zero experience in cold temperatures, but my recollection is the issue with mineral based hydraulic systems in cold is related to their BENEFIT - mineral brake fluid is hydrophobic , so water in the system separates out and then collects around the calipers
Though I also wonder how cheap the brake fluid Zoom uses in the brakes aventon sent me. The front which had no growth came out nearly clear when I did an actual flush of both.
And I mean a real flush; hot water forced through the line, then isopropyl, used a new caliper on the rear since Aventon sent me a spare (it came not working) and actually boiled the handle before again hitting it with IPA to help drive out moisture.
Though I'm wondering if the replacement I got off Amazon before Aventon even bothered responding to my help request was the one that was contaminated, or if I accidentally did so when I did the replacement initially.
Bacterial growth in fluid lines is a constant woe for me as a computer tech. This whole "liquid cooling" trend being a magnet for mold even with the additives people use. Especially homebrew and/or custom tubing, though we've seen a number of AIO's die for the same reason which is worse. With custom loops you usually use clear tubing so you can see the dye added to the water, so you can see when the colour goes funky. AIO's use rubber tubing so you can't actually see what's going on.
I wonder how mineral oil would behave compared to the water. I mean, we used to submerge whole computers in the stuff.
