How to change the advanced' menu ?
Please kindly press the up and down along with power until you see OK on the screen then let go and press the up and down again until settings come up, you should now have access to advanced settings.
Here's the link of X3 Pro display user manual:
Color screen display is located on the middle of the handlebars has many features including Password-protected, Throttle Assist Boost, and Advanced Metrics View Mode to name a few. The dashboard have USB ports for charging other devices, it can be a nice convenience feature if you like to use...
wallkeebike.com
How to install the pedal:
The pedals have a letter indicating which side of the bike they install onto. Pedals are marked “L” and “R.” The left side goes on the right Crank. The right side goes on the right Crank. Pedals are not designed equally. Please note the left pedal is reverse threaded...
wallkeebike.com
Here's the picture of the X3 Pro Battery Installtion, please kindly check the attachment.
What are the keys for?
The keys is used to lock/unlock on the battery.
Please take care of your battery key, we don't have copy keys for sold battery. If you lost it, you need to change the battery box.
3 Modes For Riding
- ECO mode: twisting the throttle with pure electric power.
- PAS mode: Pedaling with the power assist. Riding will be easier and more energy-efficient.
- SPORTS mode: Pedaling without electric power. Exercise whenever you want (or the battery run out), burn more body calories!
Pay attention to the following situation:
1. Charge the battery frequently. If you do not use it for a long time, please charge it once a month. Keep the battery clean and dry.
2. Try to use the original charger when charging. Do not cover anything on the charger, it should be in a ventilated place.
3. Before riding, check whether the bike is in good condition, whether the tire pressure is sufficient, whether the brakes are sensitive, and whether the screws are loose.
4. When using the throttle, accelerate slowly from level 1 to level 3. It is recommended to use pedals to assist when climbing.
5. On the premise of ensuring safety, don't brake or start frequetly. When walking the bike, turn off the power to prevent the throttle from starting suddenly.
Is there a way to raise the handlebars?
Bike fork stem extender is a helpful tool to raise up the head handlebar of your beloved bicycle, and bring you enjoyable and relaxed cycling experience without bending the body too low. We suggest you can buy it on the Amazon.
Search the keyword on the Amazon: Bike Handlebar Riser OR Fork Stem Raiser Extender Head Up Raiser
