KenM.
Hi Rich, sorry it took me so long to reply to you, I had a lot to do today.
Yes I like the bike a lot . I weigh 170lbs. The bike weighs around 47lbs. I use pedal assist no.3. I like to still pedal like a regular bike. On 3 it just a little easier than the Schwinn road bike I have. I also do not like to charge the battery up every time I want to ride.
I had it in pedal assist 5 a couple of times, that is fun. It is like having a tail wind all the time. The last time I had it in 5 for about 12 miles. There was a head wind of about 15 to 20mph. And I was still going between 12 and 13mph. And I only had to put just light pressure on the pedals.
If you use number 5 all the time I think you would only get about 25 or 30 miles out of the battery.
The bike is not a fast bike, only goes about 18mph. In pedal assist . It has a 250 watt motor, so it keeps it light weight. The battery only weighs about 1 1/2lbs. Light weight, lets it go so far on the charge.
I did have it up to 21mph. once, but you have to pedal like crazy.
I do not like to pedal real fast. It needs a taller gear up front, then it will be good for higher speeds for me.
Thank you for you post. I will be glad to answer you anything that I can. Thank you , ken.
