Gearing Swap - Suggestions
Saf
Ok. So I swapped my chainring to a 52t and my freewheel to an 11-32t. The derailler is maxed out on tension. What would you all do to fix/remedy the solution. I’m not a pro but I love to mod.
new derailer - short or long?
New chain?
suggestions please. A picture says a thousand words.
Not sure why you did both. The freewheel alone should have been enough. If you want to experiment, why don't you get a short piece of chain and some master links?
I did both to maintain a strong first gear for hills and get a better 7th (11t) for speed. I’m running out Of pedal when I was just on the chainring. Chainring was replaced after an accident.
If I add a few links, how straight should the derailler be? 90 degrees or?
thanks!
thanks!
You need more chain. Assuming clockwise rotation, 90 degrees would be fine while on the 32t, but you should also measure for slack when on 11t.
Make a long chain. Then use a piece of coat hanger to connect links and test tension at different lengths on 11 and 32.
You'll find a sweet spot and that's where you connect the missinglink or install a pin.
I am curios what the
thanks!
What was the final outcome as to the performance, once you got the chain added.
Performance was better than I expected it. I do feel the 34t was overkill maybe 32t would be better, and not 10 links... maybe 7-8 would be ideal. I’ve had the chain come off once and due to a large bump.
You don't need to change the length of the chain at all. That is why your chain comes off. I have done this swap to four Lectric bikes without the chain being lengthened.. everything is in line and the chain doesn't come off..
The only issue since I made my freewheel swap is the chain jumps to another gear but I believe that is just a derailer adjustment. The chain was fine and I have not heard anyone else need to lengthen their chains. I did hear that if you change the crank assembly you might need to lengthen the chain.
Yes..sounds like a minor adjustment.
