onlineaddy
- USA
- City
- San Diego, CA, USA
Is it near the lower pivot by the BB?Oooooh.. on the black frame - bonus points if you can spot the GPS
Close. But no. .Is it near the lower pivot by the BB?
hmmmmmmmm ?Looking really good !
Does that swing arm open up for possibly a belt ?
I can neither confirm nor deny this.Looking really good !
Does that swing arm open up for possibly a belt (with the Kindernay option) ?
You are such a TeaseI can neither confirm nor deny this.
Should be 52v 17AhWhat is the estimated max battery size / configuration that fits in the downtube?
Depends on how much clearance there is and how much protrusion would be used to make an extended battery.Protrude down from the downtube? I suspect not: that would get in the way of the suspension travel of the fork.
I do not understand. What are we looking for? GPS what?Oooooh.. on the black frame - bonus points if you can spot the GPS
It is the same integrated battery that is in the new UCP. You won't get odd size batteries because one of WW's goals is to used standardized components so you are not locked into buying replacements from them.Thanks,
I assume that is 14s 5p with 70 x 3.5Ah cells?
Could an extended battery that would protrude from the frame somewhat be a (considered) possibility?
