fooferdoggie
I weight 200 or so pounds my bike is a mid drive e bike its a bosch motor so not a motorcycle.the bike is 70 pounds with all my gear and I can carry upto 30 pounds of stuff. it is my commuter and i put 6000 miles a year on it. the stock wheel is having issues and my local high end bike shop trued it up and thinks it will always have issues. I want them to build it but it may be 3 weeks and they are out of the rims. not sure what parts they are using though they had a dt swiss rim and spokes then a dt swiss hub so I can change the end caps to a through axle when I get a new bike. the bike is 700 with a 135 spacing and a qr right now. 10 speed shimano. what I dont know is what rim width I need I run 300x38 tire. a different place to go would not be a problem.
https://www.prowheelbuilder.com/
Drillings
32 Rim - Recommended | Hub - RecommendedRim
DT SWISS EX 471 29IN BLACK DISC BRAKE RIM $114.00
700c / 29er
Tubeless Tape for 1 wheel Installed NO Valve (works with tubes as well) (Not available as Rim Only) + $6.00Hub
DT SWISS 350 REAR BLACK CENTERLOCK DISC HUB $221.00
Spoke Type: J Bend
QR Rear 10x135mm (Does Not Include Lockring)
*Shimano HG/SRAM 8,9 or 10spd (Dyna-sys Mountain Bike 11 spd compatible)
*No Bearing Upgrade
Shimano Centerlock Lockring (works with all axle types) + $13.00
*Stock 18 Point Engagment 20 DegreesSpokes
DT SWISS COMPETITION 14|15|14 GAUGE BLACK SPOKES $1.58 RecommendedLacing Pattern
Three Cross RecommendedNipples
DT SWISS BLACK 14G 12MM BRASS NIPPLE $0.20 RecommendedWeight
1016.16 gramsPrice
$410.96
