Totally flat terrain, no stops, no cargo, rider under 160 lb, DD might work for long commutes. Stopping & starting a lot, any use on hills, heavy rider or cargo, lots of time spent at low speed where DD uses waay too many watthours compared to geared hub or mid-drive. I tried DD, could use up a 840 wh battery a mile & 4 hills short of my destination (66 hills 27 miles). 1300 W ebikeling geared hub used about 2/3 the battery same route. Mac12t 1000 w about half the battery with more 14 hills and 3 miles added to keep me off dangerous State Rte 3. With 94 lb bike tools supplies water, 80 lb cupplies, 170 lb me (down to 160 this year). I stop at stop signs & traffic lights.
"Waterproof" connectors don't impress me. Putting the rectangular white connectors under the seat with drip loop has worked for me in this area where it rains 220 days a year. What did not work was an ASI controller with a connector with pins 0.5 mm apart. Harness too short to mount that controller under the seat, and rain shorted out +48 and negative and burned the pins into the Mac12t wire harness. Rectangular white connectors are about 1.5 mm apart and that seems to be adequate. Hard to buy anymore, those juii connectors can be sold as "waterproof" but the real advantage is that they cant be modified by popping pins and moving. The purchaser is locked into buying his controller & motor from the same vendor, all years in the future. Ebikeling parts from 2022 to not match motors+throttles+PA pickups from 2018 Buy buy buy, repairing anything prohibited or extrremely difficult. I finally did it but I had to dive into scooter controllers with no PAS pickup and no display.
