thatpondguy
- USA
So my display unit that's being used on a Bafang BBS02b motor with a 52v 20AH battery has these settings:
The bike is a 27.5 on WTB Trail Boss 3.0 tires w/ a 1-10x (now limited to 1-8x) with a 30T Luna chainring.
The display is a "Digitech b-cockpit BL181"
S1 Wheel Size 4.0 – 99 Inch 0.5
(This one was easy, selected 27.5)
S2 Perimeter 0-9999(Calculated by wheel size by default. 3.14*D)
(This one auto-populated based on selection 27.5 wheel size)
S3 Speed Unit 00:Km/h None 00:MPH - -
(I chose MPH)
S4 Speed Limit 00 – 99 (0 means no speed limit) km/h 1
(I chose 0)
S5 # of Magnetics 1-99 / 1
(I have no idea on this one - it's defaulted at 1. What does # of magnetics mean or do?)
S6 Backlight 1 – 5 / 1
(I chose 1, perfectly visible)
S7 Auto Power Off 0 – 99 (0 means always on) min 1
(Left at 10 default)
S8 Protocol - 00:KM5S;-01:Li 2;- 02:Customized
(default of 01 - anything else gives an error)
S9 Voltage 36;48 V -
(So for this I chose 48. It was default at 60 and was working... No option to choose 52. Leave it at 48?)
SA Electricity calculation method - 00:The controller reports the voltage, and display calculates - 01:Controller reported power;- 02:The display detect the voltage and calculates
(This was defaulted at 01, but was showing a newly shipped battery at full power... I changed to 00 and the power is now reading less than half. I'm hoping this is the more accurate choice?)
Sb Walk Mode 00:Yes; 01:No - -
(Chose "Yes" to enable walk mode)
Sc Default Assist 0-max / 1
(Chose "1" to start display in assist level 1)
Sd Max Assist 1-9 / 1
(Chose 9 to have 9 levels of power)
SE** Logo - 00:Digitech(Default);- 01:Neutral welcome screen;- 02:Customized Logo
(Not really important, left it at 00 default)
SF Reset 00:Yes;01:No
(I believe this resets all settings. Left at 01)
SH Serial communication00:3.3V;01:5V - -
(Display controller was defaulted to 5v, changed it to 3.3v and works fine. Which should it be?)
Any suggestions or recommendations on the red highlighted text would be much appreciated. Thanks all!
(I chose MPH)
(I chose 0)
