Cycling Shorts?
I turned 70 on 10/3, so incontinence is most likely on the horizon!🤪🥸👴🏻
I’m 75. Incontinence was a concern a few years ago when my prostate suggested rolling into a ball and limping. Treatment worked. Now my saddle helps hold it in.
The most important thing is to follow Larry David’s rule: “Go before you leave”.
Well I am definitely old enough where trusting a fart is always a gamble. So maybe my biking shorts should be a very dark color.
In-Continents from Australia to Europe and Asia, ridders find these padded shorts to be plush, with the added benefit of not needing to stop as often.
Good quality shorts and jerseys last a long time, (I wear bids instead of shorts). My favorite jersey is nearly 20 years old. Hand wash and air dry.
I also prefer to have a variety of bibs so that I avoid hot spots.
I find that my ‘Depends’ give me all the support and comfort I need!
Plus on the longer rides there’s no need for a bathroom break!😉🤥
These ones are good it comes with skin tight padded liner that you can wear without the shorts. It's strech fabric fashionable enough i wear on the golf course not just for ebiking.
About to break down and try some cycling shorts and tights for a single reason not mentioned so far.
Unlike my midriff, my butt's lost some volume in recent years. And that leaves a good bit of slack in the seats of the regular shorts and pants I like to ride in.
Problem is, that slack sometimes snags on the nose of my saddle when remounting after a stop. And that can be a safety issue when trying to squirt through an intersection — especially without a throttle. The long nose on my hub-drive's sqLab saddle is especially snag-prone.
Hoping that the tighter fit of cycling bottoms will eliminate this hazard. Appreciate all the shopping tips here.
I had the same snagging issue. Instead I changed the saddles on both my e-bikes to Selle’s saddles with the Concorde (droop) noses so I didnt have to change my wardrobe 😜
Agree, would much prefer to avoid snags AND costume changes. Will definitely go in the droop-nose direction with future saddles.
Problem is, I hate playing saddle roulette and am loathe to keep experimenting once I find one that's reasonably comfortable — which is where I'm at with both bikes now. Took 5 iterations on the first, more upright bike, and the 2nd came with the most comfortable saddle I've ever had.
Wait, I think I just solved my own saggy-snaggy pant-seat problem!
Hey, if it's good enough for superheroes.... Easy-on, easy-off. Good pocket and quick fly access, too!
Well, maybe not. Pretty sure the dog's thinking, "Man, I hope he's not planning on wearing that when he's with me!"
Update, my hips were still causing serious pain if I rode more than 3 hours. My commute to summer camp is 3.7 hours. I was using an evo cruiser 218x260 saddle with 1 cm padding. I bought a pair of Bellwether 02 mens cycling shorts, which turned out to have a 1 cm plastic pad built into them. I rode those for a month, under my dickies long pants, but the wide pad caused my inner quadriceps to twitch and spasm after my ride. I replaced the shorts with a selle royale explora saddle, which still had only 1 cm padding. However on top of that I put a cloud-9 double gel seat cover. 2 cm padding makes 4 hours comfortable in galvin cotton/poly briefs under dickies. Pity nobody will sell a 2 cm foam padded seat. Cloud-9 is not an option, my bike has a weird oversize seatpost, not 13 or 14 mm. Seat has to be rails like a brooks. My tinturi exercycle has such a 2 cm padded seat and I find it extremely comfortable. Unfortunately the post is 2 cm x 6 cm rectangular and will not fit any bicycle post or rails.
