harryS
It's always cleaner when you start a new thread. People will try to respond to the first poster and never get to your post.
It reads like you had a 17.5AH battery that would shut down on your trike, but you have a bigger BTR pack that runs it OK now. I replied that you don't need to change the controller because it has its own current limiter.
Now you're saying you took the BMS card out of the old battery and you want a new one? The old one was shutting down because the cells were not strong enough to run the big hubmotor, If you put in another BMS. the same thing will happem and it will shut down.
You probably know it's unsafe to run a battery without a BMS circuit. It's extremely dangerous. There's nothing to shut off the battery if cells get too low. Nothing to shut them off if the batteries gets unbalance, You can have a pefrectly good charger, but it will overcharge cells if the battery gets unbalanced. It's a serious fire risk. Don't do it,
Well, I appreciate the answer about trikes cornering. I thought about building one for a lady I know that can't bakance a regular bike, but I think she would flip it, unless I limit the speed to 8 mph,
