cayjak
I didn't measure the thickness of the rear shoulder on the DNP freewheel. I should have done that while I had it off. I think it was approximately the same thickness as the spacer ring, which means the DNP freewheel (without the spacer) should end up with the sprockets in about the same position as the original freewheel. So I agree, the derailleur should work...
It is very possible that I am missing some adjustment technique, or doing something wrong. I am a novice at this derailleur stuff...learning by "trial and error". The inexpensive derailleur on the RadMini only has 3 adjustment points that I can find: the H and L screws, and the barrel adjuster on the cable. If I back both H and L screws out all the way, the derailleur still won't move far enough inboard to fully seat on the biggest sprocket. I agree - it should have enough total range of travel, because it worked with the original freewheel with the same sprocket spacing. I'll keep playing with it, and reading online to further my knowledge of the subject, and see if I can figure it out.
Just thought of something else I can try. I'll drop the chain completely off the freewheel, then see if the derailleur has enough total travel to line up with all 7 sprockets. I'll report back on my results.
