pleasehelpmybikeisajuicedlemon
- USA
The power assist on my CCX is not functioning. I have had this issue since I bought the bike and have contacted technical support many times but I have been given no good solutions. I have gone through all the steps in every one of juiced online videos and articles. I have disassembled and reassembled and cleaned the bike more times than I can count.
The issue continues to be that the power assist works for about the first minute of the ride and then it doesn’t function. After the motor doesn’t respond I try the walk assist function button and there is a one second surge to the motor and then it turns off. The same thing when I try the throttle. I have replaced the tourque sensor. I have totally removed the break sensors. I have cleared the controller. I have ensured all the connections are tight. The bike functions for a brief minute so the connections must be working properly to start the ride. Then after 1 minute the power assist cuts off. If I stop the bike and recycle the battery and turn it back on the power either doesn’t function or sometimes it will function for 1 minute and cut out yet again. I made a video that shows the motor coming on for a second. The first few times are in response to the walk function being activated (holding down the minus button) and then there are several surges when I press the throttle. Link to video:
photos.app.goo.gl
Other than the obvious things, all of which I have tried, what else could be the problem or solution? The controller? The motor?
Personal rant: I have had nothing but problems with this bike since I purchased it. The bike was replaced once already by an entire new one, I got a new batteriy to replace a defective one because it fried, and I got a new tourque sensor.
Appreciate any suggestions.
New video by Mark S
