Except it is TRUE. Marsh and McClellan, the largest bike shop and ebike insurer, underwritten by Northwestern Mutual, has all the statistics on this. Hydraulics, hands down (no pun), are the worst. Caliper rim brakes, while far larger in use worldwide, have fewer issues per 1000 bike accidents caused by brakes. If you are going downhill, and not properly positioned, and you inadvertently grab too much brake (quite easy to do, since you can basically activate them like moving a feather), you are going over the top. Simple physics here. Hydraulics have far more pressure capability than any mechanical (cable) brake ever will. Cable tension can give. There is no forgiveness in hydraulics, unless you spring a leak or an air bubble in the line.
While there are a number of perceived and widely cited advantages to disc brakes ,and hydraulicly activated disc brakes, not too many people these days look at the other side of the equation. Everyone today is all about the hype of hydraulic disc brakes, due primarily (and only) their quick stopping power, and easy movement of the lever by even weak handed people.
So while we are on the topic, Lots of flawed assumptions are made about rim brakes vs discs.
Here are some other disadvantages of disc brakes in general that are rarely if ever pointed out by any bike shop. (This list is Per Sheldon Brown)
Disadvantages
- A front disc brake stresses one blade of the front fork very heavily, requiring a stronger, heavier fork, resulting in a bumpier ride with a non-suspension fork, and if a fork isn't quite rigid enough, producing 'brake steer".
- Disc brakes require special fittings on the frame and fork, and special hubs.
- A front disc brake caliper behind the fork blade generates a powerful force tending to loosen a quick release and pull the wheel out of the fork. A special hub, and a fork with a hole rather than a slot for the axle, are needed to surmount this problem.
- Disc brakes and associated parts generally result in a heavier bicycle than with rim brakes. This is less of an issue with carbon-fiber rims, as the rims do not have to be designed for braking.
- Disc brakes are more complicated, expensive and difficult to maintain than rim brakes or drum brakes. This is especially so with hydraulically-actuated disc brakes, the best-performing ones.
- Some disc brakes are grabby. This problem is more likely if dirt gets trapped between the calipers.
- Disc brakes can interfere with baggage racks and fender stays.
- The disc is vulnerable and easily bent. Other hub or rim brakes do not have this weakness. caution is needed with bike racks.
- Hub flange spacing is often reduced, resulting in a weaker wheel. Wider overlocknut distancecan resolve this problem, at the expense of incompatibility and proliferation of standards.
- It can be difficult to avoid calipers' rubbing on the rotor when the brake is not in use, resulting in some drag and noise.
- Disc brakes can howl when wet (though they work better in the wet than rim brakes).
- Pads wear very quickly compared with the shoes of rim brakes. It is a good idea to carry spare pads on a long ride, especially under muddy conditions. Fortunately, pad replacement is relatively easy.
- The disc gets extremely hot. It can cause injury if touched, and melt nearby plastic or cloth items. Care must also be taken to use the correct brake fluid with a hydraulically-actuated disc brake, so it does not boil, resulting in loss of braking power. No you cannot just use any brake fluid in hydraulic brakes. Some are specifically and only mineral oil. Some require other specific oils. You need to know this if you are going to bleed or replace the oil. And if you brake a hydraulic cable while out on a ride, good luck fixing it quickly.
- There have been complaints of disc rotors' causing injury in crashes (as can chainwheels...) - people falling on them and severing body parts.
All in all, disc brakes are advantageous on bicycles which have front suspension and are ridden in mud and snow. A large rear disk brake can serve well as a downhill
drag brake on a tandem or cargo bike. Disc brakes are less suitable for bicycles where light weight is most important and the rim can do double duty as a brake disc.
Avid cyclist and bicycle customizer Bruce Ingle has disc brakes on a fatbike he rides in winter, but he also says...
"I'm baffled at the appeal of disc brakes for
road bikes at this point, practically speaking. I can understand the allure of just swapping wheelsets just to change tire width without changing outside diameter and not needing aluminum rim braking surfaces, but disc brakes howl when wet and they're only slightly less maddening than a
chain case to remove and replace a wheel. I've yet to do so without a work stand and tools, since the caliper has required re-centering every time the rear wheel is replaced. (this is true and most amateurs dont get this). Rim and drum brakes don't have this problem, and they can be used with existing framesets."
And no folks, the difference between using them on a regular bike versus an ebike isn't really very much at all. (unless you are someone insisting on Class 3 ebike and riding around at 28 MPH all the time). E-Bike riders do not generally go too much faster than regular bike riders and even if there is a slightly higher speed average the difference between them is negligible in terms of brake type needed - in otherwords you dont need to go into a bike shop and say "OMG, I gotta have hydraulic disc brakes to stop my ebike". While most ebikes are coming with them anyway, especially for how high priced many of them are today, its not an absolute that you have to have them, and that rim brakes aren't sufficient. You are not trying to stop a 5000 lb car, where having disc brakes that are hydraulic is pretty damn important. Professional or even just avid cyclists who are in good shape, often travel at much higher speeds than the average 'joe or jane' that rides an ebike, and many of those folks still use and buy bikes with rim brakes.
Its funny how the power of US typical marketing hype does such a wonderful job in America these days about just any technology out there - I have naive people come into my shop asking me why they even have rim brakes anymore. The above is in part why. SMH.
P.S. Bike and ebike Oem's make more margin by adding disc brakes, and especially HYDRAULIC disc brakes to your bike or ebike. That is a fact. Think about how you really ride, and don't just automatically assume, that its a cheap bike or inferior ebike, if it has rim brakes on it. And that decision may even help minimize the risk of you going over the top of your handlebars when you least expect it.
