OverflySportsmanXY
My ebike has both PAS and Throttle connectors running to the controller. My PAS connector is inaccessible because it is inside the downtube and I’m unable to get to it, but the throttle connector is right at the handlebar. Does anyone know if I could disconnect the throttle and connect the PAS sensor to that connector and once again run my ebike through pedal-assist instead of throttle? The PAS is a standard Hall type sensor with the magnetic disc etc.
Any thoughts or advice would be appreciated.
