Dallant
- USA
I assume by “complete unit” you mean a spare battery vs the Range Boost?Some think there isn't much difference between the stagger and the regular frame. It is true you still have to step up quite a bit on the stagger frame. Perhaps in the end the low step will be better . With the exception of being able to attach the second battery, however since you are purchasing a complete unit to swap this may not be an issue for you at all.
