Seems like you're trying to use "Voltmeter" as a generic descriptor in-conjunction with it being an essential piece of kit for a certain type of ebike owner, it's not generic at all, it only measures voltage, a Multi-meter is much more generic!
Just off the top of my head (without standing on a pedestal)...
Why on earth?:
1) You want to do your bit to save the Earth as you travel with more than one type of ebike and the Satiator fits all. Bit like Apple & other manufacturers not supplying chargers with their products to reduce landfill, etc.
2) You couldn't comfortably afford your Specialized or Bosch ebike and had to save money for a lengthy period to be able to purchase said "quality e-bike". As a result and after it's burned many holes in your bank accounts, etc you would like to maximise your investment by limiting the maximum charge level to 80 or 90% on occasions or all of the time to maximise the life of your hard earned expensive "quality" batteries.
3) There are a myriad of possibilities whereby you may want to charge faster than 4 or 6A - stopping at a cafe/shop/store along the way of an extended tour for example.
4) You may want to charge at home/wherever at a rate below 2A to squeeze whatever life extension you can get by doing that.
5) You're an energy nazi and you want to save as much electrical energy as possible by taking advantage of the Satiator's superior PFC & efficiency.
6) Your ebike is Bosch, you wish to be able to charge at 6A or more & you reside in a region of the world that does not have 220-240VAC.
7) You require a charger with much tougher vibration tolerances.
8) You're in the Aussie Outback/wherever and you want a charger that inspires confidence where it isn't going to s*it itself with ambient temperatures of 40+ Celsius, or it's perhaps slightly better in rain or other conditions. Bosch operating temp: 0 to 40C, Satiator: -30 to +50C and if it get's too hot it's output power is derated (reduced), what does the Specialized or Bosch charger do in this scenario?
9) You are on a tour or such and you have a total of 3 or 4 batteries to charge and want to charge all of them from flat to full in one night.
10) You have plenty of money and you like to go fast with everything you do, including charging
11) You prefer to support a talented little Canadian company instead.
12) You get a Grin on your face (no pun) when you think that you own a gadget that can do all of the above things that the average Joe who just goes with the norm, does not possess.
