Durukan Devrim
Hi. I'm using a Bosch CX powered ebike as my daily commuter. Unfortunately I fell off my bike while cornering in wet weather. Bike landed on the crank arm and it bent pretty bad. Thankfully motor seems to be fine but pedalling with a bent crank is really annoying.
This is what I have on my bike: https://www.tritoncycles.co.uk/comp...sprockets-c69/bosch-2-crank-with-guard-p17559
I'm not going to replace my crank with the same one since it doesn't seem to be sturdy enough. So, as I was searching for an upgrade I realised that none of replacement cranks come with a chain guard. Then I took my crank apart and saw that the guard is riveted on the arm, so I can't just use it with new cranks.
These are the replacements I found: https://www.bike-discount.de/en/shop/bosch-system-18250/l-24
Anyone ever been in this situation? What do you think I should do?
