I'm hoping someone ( maybe @Ravi Kempaiah : ) can help me understand some aspects of Balance Charging.
I understand with most simple chargers and BMS's this is done at the end of a full charge and I understand the benefits of why it needs to be done.
But where I would like a little clarification is why doesn't a battery self balance once unpluged if all the cells are interconnected and higher voltage will always flow to lower voltage?
Is it because individual cell resistance can be greater than the potential at smaller differentials
Somebody please school me![]()
I could not agree more. You hit the nail on the head!我希望有人(也许@Ravi Kempaiah:)可以帮助我理解余额计费的某些方面。
我了解使用最简单的充电器和BMS,这是在充满电结束时完成的,并且我了解为什么需要这样做的好处。
但是,我想澄清一下的是,如果所有电池都互连并且更高的电压始终流向更低的电压,为什么一旦拔下电池就不会自平衡呢?
是因为单个电池的电阻可以大于较小差异时的电势
有人请学校我
Yes Harry I did notice that the charger light did turn green from red at near full voltage but that it continued to have a current output and that it continually decreased.Most of my chargers will flip the green led to red when the battery gets near full voltage but they don’t shut off, but keep applying voltage. That allows the balance to happen if the BMS is capable.
I believe the cells naturally throttle the current as they approach full charge, but we do want the charger to go into constant voltage mode no higher than the full voltage. If you connect a 60V supply to your 13S battery, it will not be able to force much more current than what the battery will accept, but it can try to overcharge the cells and your only protection is the overcharge circuit in the BMS.
I happen to do another full charge on my battery yesterday as I had a long ride planned and it has been a while since I had gone above 85%Most of my chargers will flip the green led to red when the battery gets near full voltage but they don’t shut off, but keep applying voltage. That allows the balance to happen if the BMS is capable.
Yeah I understand the safety concerns built into the chargers.. and it's really not a problem. This is more of an experiment and mental exercise for me.If you're wanting to fully peak a battery with a stock charger, you can let it kick off normally, then wait an hour or so for the cells to settle a bit, and then plug the charger back in. It'll only run for a few more minutes (15 maybe?) and shut off again as the pack reaches full voltage. Do that until you see the 54.6 when checked. There's no way the factory chargers will go beyond that point....
