If this system is more transparent and customizable, then i might take a chance on Luna Cycles. I emailed them.
three dog night ...
1) get a dog cart for your e-bike.
2) get a dog
3) mount the battery in the cart under the dog bed.
4) always take the dog with you in winter.
You're welcome.![]()
Yeah, you also don't want to bungee your cat to the down tube ... especially if it still has claws.Dogs are OK, until they chase after me on my bike.
I am just kidding of course ... love my pets even more than my e-bike.![]()
Insulation, of course. But the battery may heat as it is discharging...my cell phone does, at any rate.
I think aluminum could get super chilled if slush or cold water sprayed on the battery or frame. I wonder if that is all it takes for a voltage drop that cause the BMS to turn off power?
The guy who built my battery said the cells are designed to be used in cold weather - these are the Panasonic cells made in Nevada. They were tested in Michigan during the winter at three temps, 38F, 28F, 10F and duplicated what Pansonic had said: That the cells would perform like normal down to 10F
Why are you stuck on Bosch?
You are looking for a special bike, why didn't you build the perfect bike? You can go out and find any Mtn or road/comfort bike you want, as many speeds and any type of brakes. For a winter only bike I'd consider one of the fat tire bikes. If you buy it online you could have shipped it to Bisto Bikes and they will install one of the nicest geared motors you can find, not only power but efficiency as well. 48V, 700W - peaks at 1400 with two additional power stages. The battery will perform in the weather conditions you are looking to ride in. Three year warranty, parts and reasonable labor. Same warranty on the battery AND because he's in the USA you can actually return a battery to him.
Plus you can call and talk to the owner, he is a pretty sharp guy.
All valid points. I actually bought an Evelo Aurora. A compromise between your suggestion and my lack of dexterity. A major reason was the NuVinci Harmony, which makes the bike's drivetrain like a scooter CVT. i consider eBikes to be electric scooters. A CVT drivetrain is more appropriate in my opinion.
I pedal at an extremely consistent 95RPM. I might go up to 105 to 120 on a steep hill. For the most part, i just want to pedal and leave the decisions to the motor controller software. The BMS and motor controller have all the information needed to optimize battery consumption. I just want to pedal like normal. Let the computer make the calculations.
I vary torque more than cadence, if that makes sense to you? I EASILY and quickly generated 800 watts on the showroom demo, which i feel is broken. I just disregard those results as nonsense.
I prefer to pay Velofix to do the manual work, because i am inefficient at it. Sure i could save money, but i also learn from watching and talking with them.
https://www.velofix.com/what-we-do/
https://electricbikereview.com/evelo/aurora/
