Bafang brake sensor for gear shift sensor
Dannydonghi
When using the brake sensor cable for use of gear shift sensor, can the delay time be adjusted with USB cable programming?
On my controller bbs02 is an extra cable, I presume for lightning? It's 2 wire connector.
White or black flat two pin plug, it's a 6volt 3W output, depending on the display it will power up when you switch the display to dark mode or the newer displays use a light sensor which will automatically turn the lights on and dim the display,
My friend has this setup, if I am behind him when we go into a tunnel his lights turn on, then turn off once back in daylight
