The other day I was riding home from work when I heard a twig get stuck in a tire again but it fell off after a second or two before I had time to stop. I have tire liners and everything seemed fine until the next morning when the tire was flat. Ok, slow leak then. Drive to work that day in the maddening traffic jam and fix the tube in the evening...
Took the tube out, found the puncture, patched it, put the tube back in, inflated it. Everything seemed fine but after a while the tire was flat again. So it was two punctures I thought, found the second one and patched it, put the tube back in and inflated. This time I could hear the leak hissing. WTF?
Upon closer inspection I found a thorn sticking inward from the tire through the liner, snapped off so there was no sign of it on the outside and it was dried out just perfectly to achieve maximum strength and sharpness so even the Rhinodillo liner was no match for it. Life found a way, and I learned to check what's in the tire when there's a hole in the tube.
