Alaskan
It turned out that the bike came with the cassette I wanted which was the Shimano XT CS M8100 with 1-51 teeth. It was either part of a running spec upgrade or an issue of availability for production.
That cassette requires the new Microspine hub which was already installed on my bike from the factory.
As I also wanted electronic shifting, it cost an Extra $1000 to buy the SRAM X01 EAGLE AXS X01 UPGRADE KIT - which included the rear derailleur, shifter, derailleur battery, charger, etc.
The installation was pretty simple. It involved removing the derailleur, shifter and cable, mounting the AXS derailleur & shifter, charging the battery, pairing the two, and of course setting the limit screws. It did require a 126 link chain and used every link. Once everything is installed and adjusted I then downloaded the app to my phone which allows me to select how many gears are spanned with a press and hold going up and going down, as well as switching out the up and down press on the shifter.
Going with the Di2 would have taken more money and more install time as there are several different cables that need to be installed. The wireless Sram set up is simple by comparison. It is also compatible with Shimano cassettes.
Here is a review. It may be a while till I can review the bike and drive train myself as I am experiencing health issue that will keep me off my bike for a while...so don't ask me how I like it as I will be unable to answer.
Here is a review:
https://www.bikeperfect.com/reviews/sram-eagle-axs-review
and a video review after six months of use.
Here is a review:
