My name is Dan Eaton (HI), I’m an experienced cyclist, having done extensive touring in my younger days. However, I am turning 82 in July and even with granny gears, I’m finding some of the hills around where I live getting to be more than I can manage. Based on some of my initial research, I am considering step through (I had an accident dismounting about 2 months ago), rear mounted battery pack (I’m assuming they will also be able to accommodate paniers), and mid drive pedal assist. I plan to do mostly road cycling, so looking at 700c’s for low rolling resistance. Based on my touring experience, I don’t see the extra weight of ebikes having much of an effect on flat roads. I’m not a speed freak so my initial plan (unless I eventually find otherwise) is to only use the assist for those times when I actually need it. Since some of the hills around here are pretty steep (the steepest is 22%), would a 250 watt drive be able to handle that assuming I have shifted down to the lowest gear ( I weight about 190 lbs)? Any other advise on models would be appreciated.
