Taylor57
I thought it'ss about 40% more. Plus it's a second battery so that's a good thing I guess.
I dont know if it's worth it to add 7-12 extra miles of range for 340 bucks...
Depending if you have a way to transport the second battery with you then you have more than double your range and which it's better than buying it from Lectric since the battery is larger.I dont know if it's worth it to add 7-12 extra miles of range for 340 bucks...
You are right with that but the problem we have is mostly the spacing where the battery goes. More juice means bigger battery.Thats what we were trying to avoid, carrying a 2nd battery...
Looks interesting any link where you got it from?Just got this awesome handheld air compressor...has a flashlight and lots of cool settings to customize your psi easily.
View attachment 71936View attachment 71937View attachment 71938
Sure thing! Its a great buy, I can carry it in my pack and be set for any flats or changing the PSI for gravelLooks interesting any link where you got it from?
Works ok with the Schrader valve on the XP tires?Sure thing! Its a great buy, I can carry it in my pack and be set for any flats or changing the PSI for gravel![]()
Yessir, the hose attachment works for our XP tires as well as car tires...pretty nifty plus it comes with other attachment pump styles so you can pump other things like footballs.Works ok with the Schrader valve on the XP tires?
Just ordered 1. Thanks Ki!!Yessir, the hose attachment works for our XP tires as well as car tires...pretty nifty plus it comes with other attachment pump styles so you can pump other things like footballs.
Is the squeaking on the seat post annoying?This is... How do you say... Most embarrassing!
Thankfully, that worked! I had the stock spring in the post at the moment and flipped the seat around for a quick trial run before sunset here and what a nice, plush ride it is!
I have the firmer (red) spring on hand and will try that out as well but I really enjoyed the ride with the stock spring.
Picked up a 4amp fast charger for 28 bucks on amazon...I couldn’t not buy it at that price, it’s a steal.
Now my charge times are cut in half
Charger link please!
48v 20ah from ebay. Installed to controller same way on video.There’s a build on youtube of a Lectric Xp owner who built a second battery box to run and fit their second battery on.
Here it is
