A cooler (less warm) helmet?
christob
Hi; not sure of my helmet model (maybe "Max"; brand is Specialized) but it is pretty common, probably @$50 at the LBS? Has 15 cutouts / openings scattered across the top, and 6 in the rear--yet I feel like it is almost as warm as a winter hat, when I'm riding! And so far, my morning rides have been under 45°F, with my afternoon rides generally under 65°… I can't imagine how sweaty my head/hair will be when summer actually arrives, with this helmet...! :mad:
My head has always been a chimney... I never wear winter hats (just ear muffs) except in the most brutal cold because I'll just start sweating within minutes; even simply standing still in a hat, in the cold...
So I have been surprised that despite the 21 cut outs for airflow, my bike helmet instantly warms up my head… Perhaps a $50 "general" helmet with 21 cut outs simply isn't as well designed / engineered for airflow as a more expensive helmet… But I'm wondering what helmet options are out there, which are noted for either better airflow, or allowing head heat to escape more readily?
I use a helmet similar to this one. Got it at Dicks sporting goods. Around 25 bucks. Light, lots of air holes and not too goofy looking. I have one in white and one in black. When it’s very sunny out I wear the lighter one and it’s not as hot.
Generally speaking, if you look at more expensive helmets, the vents are much larger. Sometimes the manufacturer also claims they place the vents for specific types of riding; road helmets for more flow-through ventilation, and MTB helmets for slower speeds.
Hey Nova, do you think that is more marketing strategy or fact? Some of the prices I see on things aside from helmets are really excessive. Your thoughts?
Honestly, I have no idea whether or not more expensive helmets are actually cooler. Myself, I sweat profusely, but I bought a helmet from Walmart because it was on clearance for $9.00 LOL (it's a $40 Bell). A more expensive helmet may fit better, since they usually come in three sizes instead of the one-size-fits-most like cheaper lids. Lastly, some helmets have MIPS, which are supposed to be better at protecting your noggin in certain types of crashes.
I got a free helmet with my Voltbike but my heads not circular so that didn’t work. I like the adjustable inner cage on the Giro helmet and it’s very light and not too pricey.
I also wear a Giro. I bought an expensive skull cap (dew rag) to wear under it. It wicks away the sweat, has a rubber strip on the forehead to prevent anything from running in my eyes, and keeps my balding head from getting an odd sunburn pattern.
I've had a Fox Flux MTB for +4 years. It has never felt too hot in southwestern summers of up to +100 degrees. The only issue I have in summer is when the occasional bug getting caught in the openings and I feel it crawling on my head. I add a skull cap when it gets cool in the spring/fall and wear balaclava in winter (or wear two balaclava when the temps gets as low as the mid teens).
I will second the Fox, it has very good ventilation at low speeds. It may cost more but is light weight and has easy adjustment for a good fil.
General consensus is a bike helmet's life, barring any accident, is only three years afterwhich the foam core begins to deteriorate. There should be a manufacture date in each of them as to when the helmet is made. Seems short but it may make a difference if involved in an accident.
I didn't realize there was a shelf life to bike helmets. I just figured they are A-OK as long as you didn't have an accident with them?
Don't listen to him.
"Helmet Impact Performance Proven to Hold Up for Decades"
https://helmets.org/up1505a.htm
https://helmets.org/replace.htm
I got a nice Specialized helmet from a Specialized store, for $40, half off, because it was last year's model. Try calling around local shops and asking if they have any on sale. I believe Abus is the only company selling helmets that are designed expressly for class 3/speed pedelec (28 mph) ebikes.
