80$ Li-Ion Battery Pack 48V 10.5Ah 500w output, Metal Enclosure, For E-Bikes, E-Skateboards 13s bms
ebikr480
Condition: Discharged and Re-Charged less than 20 times. May have some scratches on the metal case that do not affect performance.
Weight: 6lb with metal enclosure, 5lb without
Measurements: Lenght: 18.5” (15.5 without case) Width: 3.25” (2.7” without case) Height: 1.7” (1.5” without case)
Casing: Metal
Nominal Voltage: 46.8V
Limited Charging Voltage: 54.6V/3A
Resistance (23 ± 2 ℃): ≤ 250mΩ
Charging time: 4-5 hours
Cycle life: ~800 cycles
Nominal Capacity: 10.5Ah
Watt Hours: 491.4Wh
Minimum wattage output: 500w
Amount of cells: 39
Cell manufacturer: Panasonic-Sanyo
Cell Size: 18650
Cell model: Panasonic-Sanyo NCR18650GA 3500mAh
BMS: Installed (Low Voltage, Overcharge, Temperature, Current output and Short Circuit protection, with power equalization output)
DOES NOT COME WITH CHARGER
Stromer and Bionix have identical connectors.
All payments refundable via PayPal if subpar quality
pm
I do this have this/these (wholesale available) located in Boston. Also can be bought individually. Domestic shipping charge of 20$ that will cover up to 6 batteries
