15mm Front Thru Axle to 9mm Thru Axle Quick Release
BillyKidd
The Quick Release front hub standard is 100mm wide. The wider "boost" spacing of 110mm emerged for 15mm thru axles used for MTB but did not become common in the QR hub market typical of road bikes. A wider 110mm QR adapter would have few customers.
As you won't be riding on this adapter, I suggest you can modify one to suit your needs. You could cut the 100mm adapter in half, add 10mm of washers, and thread it all together with a rear QR (they are longer than front QR)
