Thanks. Do I readjust it back to where it was or is this ok? There is a small silver allen screw at the bottom of the caliper. Confirming this will give me less travel at the hand brake lever?no its not. you need to adjust the pads by turning the screw that causes them to move inwards. no clue on those cheap brakes where that is I am sure you can find it online.
yes adjust it back. yes moving the pad in will solve the issue its something you have to do on a regular basis as the pads wear.Thanks. Do I readjust it back to where it was or is this ok? There is a small silver allen screw at the bottom of the caliper. Confirming this will give me less travel at the hand brake lever?
I concur.Found the actual calipers, those are "semi hydraulic calipers" so the single way to adjust these brakes is by shortening the cable length by adjusting them via the barrel adjusters.
the OP asked how to adjust the lever actuation, in this case "shorten the cable" based on the type of caliper. Based on a system which has been setup correctlyI concur.
Yes I agree....the OP asked how to adjust the lever actuation, in this case "shorten the cable" based on the type of caliper. Based on a system which has been setup correctly
