Clean Custom Conversions
Edit: The saddle has a blue logo on the back that says in white lowercase cursive ism and on the side is says sport. I just noticed when I put it on the charger.
I had a similar one that claimed it kept you in the saddle under extreme g-forces.. It had g-ism written on the back 🙃
A young teen and his grandmother purchased a single speed Schwinn coaster brake used bike in new condition at a church sale for $70. They do not have much money and wanted a simple low cost conversion. I just did this. And, yes the time stamp is off.
@Frank/Delaware
It is a lot of fun even if it can be ghost pedaled. It is the very most basic eBike I have ever ridden.
S861 Display Programing for a coaster brake single speed cruiser: These displays typically have 20 settings. This on just has 9. Long press Up and Down, and scroll using the power button.
I set P06 to 6 minutes. He can still say Hi to a buddy on a multi-use path. I set P07 to a 31Km speed limit, given that the gearing is so low he will spin out at a cadence of 90 at 15 mph anyway. For all my settings 1= 26.4 accounting for the 2.25 tires. 2=96. 3=3. 4=1, 5=36V. 6=6. 7=31 8=3. 9=0.
P01 is wheel diameter.
P02 is the factory number of magnets in this motor
P03 is no throttle, pedal only. (1 is only throttle, 2 both.
P04 I do not recall.
P05 is voltage.
P06 Timeout off.
P07 is speed in Kph.
P08 is how it gets speed data.
P09 I don’t recall. But I know that you are not supposed to change it. Maybe it is max amps protection.
This bike has been to Burning Man five times and was never washed. Two of those years were mud pit rain years. It was rusted to hell. The chain was rusted solid. I finished the conversion this morning. How long does it take to replace a seatpost; ten-hours.
She is a friend. I know her husband well and her kid doesn't normally talk to anyone outside of family but he talks to me enthusiastically. They have me over for things such as Christmas dinner. We have bike rides, picnics and fly kites. She is close to the age of my eldest son. I am sort of an adopted uncle. The creativity class has been fun and I am coming up with novel solutions. I have been waking up at 4:AM for the past few days to come in and work on bikes. Now I am beginning to feel it. And it is only 10:30 AM here.
I am not allowed to read or post for a week. No streaming. No books. No radio. It is part of that class assignment.
I made this whale shaped chart for programing 48V batteries. The idea is to get the same miles per bar. The drop in volts on the first bar used is 3V and the drop of the final bar is 4.3V. The gray area on the chart per bar is the same area. If each bar instead had a voltage drop of 3.6V, the miles on the first bar used would be much higher then the final bar.
Worked well... You should make it a full time assignment 🙃
It sure boosted my productivity last week.
You won't believe the bikes people are bringing in if I told you. It is like Bears on Wheels. The tandem comes apart in three sections and fits into two suitcases. It is getting a front hub motor to assist a bit with the hills around here. Then when it goes to places such a Portugal in the Winter, the motor drops out, the battery removed, and the original front wheel is used. The rickshaw needs to carry 600 pounds up hill. The first step is to remove all the old electrical. It will take so much work. I will need to remove the large Dutch motor but preserve the differential. It is rusted to hell. It gets a new motorcycle lever left, rear. Then as a last step, I need to have a new top made for it. That maker is already on it.
Under "clean (and easy) conversions" I doubt if anything current comes close to Keyde hub motors. Simply swap in the wheel, single wire to battery (Keyde batteries are UL certified) and phone app to control.
I've had mid drive, friction drive, this Keyde hub drive on this old mountain bike. Everything has advantages/disadvantages but this allows original 3x10 gearing which mid drives don't, 11 speed cassette compatible rather than typical DIY hub drives which have spin on 7 speed freewheel, and actual usable assist vs friction drive (don't even bother). Weighed with hanging scale without battery this bike is 32.8#. Without the heavy steerer extender and long stem, sans kickstand, lighter 1x or 2x crankset, lighter than Schwalbe Marathon tires and sans the generous amount of Flatout, lighter carbon fork and I think this old mountain bike would easily be sub 30# without battery - probably ~28#, depending. Keyde 10.5ah battery weighs 4#. I'm surprised that there aren't more posts on this and other forums about this system. Not perfect but pretty good IMO.
Yes controller is in motor. It is lower power compared to my mid drives TSDZ2 and Yamaha at 35nm but retaining the original drive train and light weight is nice. Also it's only cadence sensing, they do make a higher power (45 or 50nm) same dimension unit that has an inclinometer and some sort of torque sensing function - I almost purchased one of those but refrained.
Some cadence sensor bikes can be programed in about 20 ways. I make them start at 1 volt, without delay, or lag, and I take the overrun time way down. Having some power is like washing your hands in warm water. It is nice and does not need to be ice cold with no power or boiling hot with power.
The low available gearing with this bike, ~16 gear inches, makes up for lower power. I don't mind climbing slowly on steep hills, it gives good assist on moderate climbs and I don't need assist on flatter grades so it works well enough for me. It has an internal temp sensor which I watch on climbs and back off assist if it heats up, which hasn't been an issue except on very hot days on long steep climbs in highest assist. No problems while keeping assist in lower levels in that case, which is still helpful.
I set my mid-drives to go into a 30% power limp mode until the internal temp goes under 100C. I do not know anyone who has done that yet, but this region is cool in the Summer. The rider can still go but not at normal power levels. I can also be safely set in programing to 90% of controller capacity which is 20 amps on a 48V nominal, not for speed but for big climbs. That is 864W on a 500W nominal motor when setting the max to 18 amps. One bike packer was chased by seven hunting hounds and got away. My thinking there is that for a single and senior bike packer, having power on tap in a crisis is about as important as having stopping power.
Grin's Cycle Analyst has been doing all that for 6+ years (I'm just not sure how far back some of the features were first introduced).
The simple point is that the protections and power additions occur gradually (via programmable ramping) so there's no whiplash or sudden loss of power. For example my power roll back protections start fairly subtly (so much so that they usually surprise me) - at motor temps over 90C, or when the 52v battery goes below 42v. The power ramping occurs when either the rotation starts off or when my cadence increases (it feels quite "torque like") which all provides something close to a normal bicycling feel (particularly when the bike is providing 100-200w and I'm putting in the another 50-200w so the acceleration tends to occur quite smoothly). Plus like the ToSeven DM setup it's all power based so everything is available regardless of the speeds involved.
I agree, having that additional power on tap is indeed important - particularly for a senior bike packer, and I think it's even more important and safer to have that power available quickly (dare I say instantly) and without moving your hands around or taking your hands off of the bars. This is where the addition of a throttle might have made her safer (what if those dogs had been closer or a little faster?) and would likely have also helped in a few situations she described earlier on in her tour (starting off at the bottom of loose gravel hill or the help just getting the bike over obstacles like fallen trees). The throttle can give you that power a little faster and with a little more control (both by keeping your hands in place and only applying enough power for the situation such as walking the loaded bike over an obstacle). On my road bike I often use it to manage smaller but seemingly continuous rolling hills so I can keep my cadence up and consistent without having to switch my PAS levels up and down ... but have also had to show a few dogs the almost instant acceleration. The biggest benefits for me though comes from the extra safety a throttle provides at crossing intersections and especially when loaded down ... a very similar use case to the loaded bike packer.
Now if we could only keep the idiots from abusing this helpful feature so it doesn't get banned or restricted in the very situations where it's most useful.
@mclewis1, I respect your perspective. We agreed not to have a throttle on that particular bike. That topic was discussed. It was partially the aesthetics and her riding style. To have at throttle with that particular motor requires an eight mm thick wire with add-on connections for cut-out levers and the throttle. Her bike has one 4 mm wire from the controller to the display, With no visible connectors It looks bike, like a shift cable or a hydraulic hose on a regular bike. It blends in. Also, she is a true cyclist. Over last Winter she went to the Texas hill country to ride analog bikes 500 miles per week in the hills with loaded panniers. She can adjust between the 15 power levels by pressing her thumb as easily and quickly as using a thumb throttle. On that 48V nominal system she can ramp from 10 watts of draw to 864 watts on a lightweight 500 nominal mid-drive. It was programed to not have pedal lag like on many mass produced bikes.
Last week a Walmart bike came in. It had a lag of three full revolutions of the pedals before the motor kicked in. When it did it bucked the older female rider off. I wanted to lessen the lag and have some power ramp up for smoothness. The only programmable feature was kph or Imperial. The rest is hard locked when it was flashed in the factory. There is no code or other way to get in. The couple returned it yesterday. I can imagine the legal team having a meeting with the marketing team. The lawyers insisting that it must be locked unhackable for liability in all North American markets. The marketing team instisting it must give a thrilling test ride. So my client got the worst of both.
This one came in from 2018. I think is the first one that I ever did all through frame. I just cleaned it up, gave it a new chain and rear cog, and lubed inside the motor. It is a flash from the past. I have learned so much since. It is a Nexus 8 coaster brake cruiser. With a TSDZ2 (a). The battery is still good. How clean are the wires at the handlebars? What is funny is that it will still out run and outlast a 2026 Specialized Vado SL of the type @PolishGuy thinks is the greatest @Jeremy McCreary, and @PCeBiker. Specialized batteries are meant to fail at two-years, so owners' need to replace them at a cost of up to $1,000 regularly. This premium one is non-proprietary and already out last theirs by four-times and is still strong. No lycra required.
I love it when we are cruising together.
Interesting to me at least. Sears bike that I bought when I was 13yo and has followed me across the country in several moves. Sort of Frankenbiked now with 700c wheels along with some other stuff. You can see from the seat height that I thought I was going to grow tall like my other relatives/cousins - didn't happen and I can barely clear the top tube just like back then. Front wheel from a Walmart hybrid bike that I had changed wheelsets so it was sitting around, rear is a Keyde P110 hub motor that I laced into an Alex Adventure rim with generic Amazon sourced stainless spokes - wheel lacing is relatively easy to do and I've never experienced a broken spoke on previous wheels that I've laced. The Keyde P110 is supposed to have "torque sensing" which is probably just input from an inclinometer. If weather is good tomorrow I'll test how well "torque" setting works in real life, riding it to the gym which has longish sections of 8-16%+ grades, total 928 feet climbing in 4.5 miles on way home, total over 1100 feet climbing in 9 mile round trip (over 1700 feet climbing in 10 miles if I ride to top of neighborhood road both ways).
