Steel chainring with forged alloy crank arms and double chainguard. Compatible with 3/32` chains. 45mm chainline TECH SPECS Type Length/Teeth 170x52 Spindle Type 118 SQR JIS Color BLK Bolt Pattern N/A Weight Speed 1
Yep, which is why I don't want to buy a crankset that doesn't carry about a 65 chainline. The mathing here throws me a bit, since the BB number would need to be reduced by half, but there's more to it, yes?
A standard BB fits a 68 to 73 frame shell. The difference between then in the length of the square taper shaft. A triple ring takes a longer shaft and you would want to balance that with the Q on the left. The shown ring should work fine. And should be the same distance from the center of the bike as the existing ring, because of the shaft length and taper.
