Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
For a few years since I started riding e-bikes I had 72 cm memorized as my "saddle height" (the distance measured from the centre of the bottom bracket or rather the mid-drive motor spindle in the straight line along the seatpost to the surface of the saddle). Once, I took a Specialized pedal bike for the test ride; the LBS mechanic set the saddle a tad too high. Unawares, I completed a rather short ride (some 34 km) devastated.
The years were passing by and eventually I discovered my optimum saddle height dropped to 69 cm. OK, I had it set on my two e-bikes since; it is natural for a human being to shrink in the old age.
On my latest ride, I managed to raise the saddle "a little, by feeling". It turned a nice ride into a disaster: I was pedalling inefficiently and my groins hurt. After the return, I dropped the saddle on that e-bike (Vado SL) to the original height and the situation went back to normal. Or, I thought so: I still had a feeling I was slightly hanging on the saddle. Testing the saddle height by usual methods. For instance, put your heel on the pedal and rotate the crank so the leg is fully extended. It all seemed normal.
I gave this Saddle Height Calculator a try. The results produced a ridiculously low saddle height values. I tried the LeMond method: measure your barefoot inseam in cm and multiply by 0.883. That also gave the lower saddle height but not as low as the calculator.
So I dropped the saddle by 1 cm/10 mm (it is a big deal). The outcome: I feel low on the e-bike. Nothing dramatic but I must have got used to the previous setup. No gain on the measured leg power. Only I realised the saddle pressure on my butt has decreased.
I feel helpless... Opinions? Experiences?
