Amazon Stops Selling Illegal eMotos in CA
On the Bafang...
If you enter the Start/End voltage properly in the programming. It should give you full smooth range on the rotation
So in this example...
Start: 0.9
End: 4.0
I'm gunna meter my throttle again, but from what I remember, the throttle would need to have mechanical stoppers at the two lines drawn on my throttle to eliminate the dead spots.
It can't be done by adjusting the start and end voltages.
It puts out the same voltage (something above 1.1V for a KT controller, or you'll get a throttle fault) and stays at that same voltage until the throttle is twisted to the first line.
Then after the pointer passes the second line, it put out the same voltage (something less than 4.2V) until the end of rotation.
That is for my hub-drive which uses that reverse voltage thing, but my first ebike is also a hub drive and uses a proprietary throttle, (which is just a mid-drive throttle) and IIRC, it behaved the same way with the dead spots.
Perhaps my left hand throttle Will put out 0.9V because it's for a Bafang mid-drive?
EDIT:
I think I found it,..
It says 65° rotation angle.
Does it actually have a 65° active "sweep angle" from the start of power to maximum power?
My throttle is only has an active "sweep angle" between the two lines with huge "dead spots" before and after the active area of the sweep.
Almost half the sweep angle is dead leaving me with a pretty twitchy throttle response.
2mm of "pointer" movement has about a 5 kph speed difference.
The throttle doesn't end up being very granular at all.
(I am used to it though.)
I would move it so it is in between the brake lever and shifter. That way you get use of the full grip. I recall them has having about 50 degrees of movement and being highly sensitive to the amount of push. But that could be a programing thing. The little moped bikes are mostly off/on. These are on very nice Velotric commuter bikes for adults that are smooth and easy to adjust to any speed in the bike's range. It kicks in with very little pressure and the bike will start at a walk assist speed.
,.. It kicks in with very little pressure and the bike will start at a walk assist speed.
That's exactly how I programmed my "throttle gears" (PAS modes) on my mid-drive.
I'm starting with 1 amp in throttle gear #1, so like fiddy watts. 😁
Now I need to extrapolate reverse exponentially to 18 amps at throttle gear #9 🤔
I'm stopping at 18 amps even though I have a 30 amp BMS's and a 750 Watt mid-drive motor.
I'm still all about range and I don't want to "strain" anything on my ebike, or shorten my rides to probably less than ½ hour?
Two motors getting 18 amps each is Plenty of power, and I I'll only be able to do that (without going faster than 20 mph) if I've got a 30 mph headwind.
I'm thinking that won't be a no-hands day of riding 🤔 😁
Off topic again, forgive me. An Eastern Ero. Lycra guy, who is a spokesmodel for one particular brand lobbied to have my thread taken down that opened with a version of a Bob Marley song. It was intended as humor and entertainment. He was upset and offended by it. I had forgotten its existence. It was up for years. He also pushed to have a comment that talked about the Right to Repair removed. Both efforts worked. Why not just hit ignore?
That entertainment humor thread was about passing a particular model of bike that began with the letter 'V' from a company 'S'. His tops out at 15 mph. It was initially going to be Creo but at the last second I changed it to 'V_do. Now lots of EBRer's refer to reafer by that 'V' word. I smoke (past) two V_dos in the morning...
The thing about karma is that I do not need to do a thing. It just happens.
So does my old POS e-bike,..
It only goes 22 kph, then the motor kicks out.
If it gets to 25 kph, regeneration kicks in automatically.
I'm pretty sure it's a Polish ebike?
The handlebars are upside-down ??
I have a handmade Polish bike. It does 45 kph and is a three speed with a coaster brake. I wanted a Pashley but could not afford that handmade starter bike at the time, so settled for a Creme. @Gionnirocket thinks it is metro-sexual at best. It is fun around town and still takes trails after I put gravel tires on it. I has two sizes of batteries depending on the ride. I would be in regular clothing and pass guys in Spandex on $15,000 eBikes, up hill while sipping my coffee.
