How wide are your handlebars?
spokewrench
Years ago, I got tennis elbow soon after buying a Radrunner. The pavement around here is bumpy. Each bump causes a sharp deceleration of the bike. You lurch against the bars. When I took my left hand off the bar to signal, I'd lurch against the right bar only, requiring tremendous torque with my right hand and ( and elbow ) to keep the handlebar straight. That tore an elbow tendon.
I moved the seat back for better steering control and discovered several fringe benefits. One was that my legs could help stabilize me against lurching. My tennis elbow healed.
I bought a Radmission, a one-speed that looked like a traditional 3-speed. Moving the seat back like a classic 3-speed improved handling, pedaling, and comfort, but it felt a little unstable if I took one hand off the bar. I didn't know why.
My Abound was great unless I had to take a hand off the bar. It seemed as if one day I would go into oscillations from which I could not recover. For two weeks I rode the Radmission while I awaited a replacement part for the Abound. I noticed that the one-handed instability was less severe on the Radmission. The Abound's bars were 72 cm wide. The Radmission's were 67.
I swapped bars and the Abound felt more stable. I realized why. Legs can't absorb all lurching on bumps. Most of the pressure from a lurch probably happens at the base of the thumb, about 9cm from the end of the bar. The one-handed torque I would have to apply against a lurch would vary with the distance of the base of my thumb from the center of the steering tube. With a 72 cm bar, that would be 27 cm. With a 67 cm bar, it would be 24.5 cm. 24.5/27 =0.907. One-handed, it took 9% less torsion to maintain control with the 67 cm bars.
I checked with Sheldon Brown. For road, street, and gravel riding, the standard width is 48. Longer handlebars are for mountain bikes because they offer more precise steering at very low speeds on rough terrain. In a situation like that, I can touch a toe to the ground. I'm more concerned with the possibility of being thrown on my head because I hit a bump while signaling with one hand at 15 mph.
Brown said wide bars often come with marks for those who wish to cut them shorter. I haven't seen any marks, but I will caution them shorter.
My Jones H-Bars did indeed come with markings to cut it shorter. Which I did with a pipe cutter.
Outdated. Sheldon Brown is not among us since 2008.
For road or gravel, drop handlebars it could be anything from 36 to 48 cm, depending on the rider's arm spread. Gravel handlebars are flared to increase the hand spread in the drops for more precise ride control in rough terrain.
A typical modern all purpose flat handlebar bike has the bar width of 66-68 cm.
MTBs -- depending on the subtype -- can have anything from 75 to 85 cm.
It is not the handlebar width that decides about the bike stability but the bike geometry, where the handlebar width is never reported.
I also use Jones H bars, which I cut down from 710mm to 660mm in order to clear vehicle barriers on trails I ride.
I also experienced some of the symptoms you describe, and along with the Jones bars, I also added a Redshift Shockstop suspension stem.
I chose the 2.5" rise, but other options are available. The combination of the two all but eliminated many of the discomforts you mentioned.
The chain drive made the modern bicycle possible, but riders preferred high-wheelers until John Starley's Rover in 1885. He had improved bicycle geometry by moving the seat well aft of the crank. What's more, the seat could be adjusted fore and aft as well as up and down.
Brown wrote about what had been learned about bicycle geometry in the next 123 years. Did that become obsolete 18 years ago? What is a typical all purpose flat handlebar? If "all purpose" means "fashionable," that may have changed in the last 18 years.
Are these people wrong?
They say that except for mountain biking, handlebar width should be close to shoulder width. With the two bikes I have now, headwinds are much worse than I recall from years on a 3-speed. The bike fitters say yes, wide bars increase air drag.
For stability, I wish I could increase trail. It's only 6cm on my Abound and 7cm on my Radmission.
My shoulders are about 40cm wide. I've never ridden the latest shifter setup with splayed levers, which could change the calculation a bit.
I decide flat bar legnth by body size and comfort. I prefer bar legnth slightly wider than my shoulders width which makes for a comfortable sleek fit but still provides enough steering leverage. Personally that's about +30% wider / 66cm
