Vado SL 4.0 with a suspension fork?
A normal steerer tube.
I don't think that is a precise enough answer if it referencing a Vado SL. The steerer tube is customized for the future shock system. As far as I know it's not a standard diameter.
Example is to delete the future shock, you need a custom part.
collecting a 2nd hand vado 4.0 Sl this weekend. I'll frankenbike it with a suspension fork from an old hardtail mtb just to prove the concept, then work out what to actually fit.
Good stuff! Was it via ebay or a local shop? Good deal?!
ebay. £1k, which is about right. My understanding to-date is that its will take a 1-1/8" straight tube fork. hoping that one of whats in the garage will fit that, for the test purpose.
Thats a very good price. Fingers crossed on the conversion. Really interested to see the result.
got it last night. morning of tinkering. starting point, I'd already taken the front wheel off
stock specialised fork removed
removed the city bike bits, swapped fork and front wheel from an old Giant Roam "trekking/city" bike. 60mm travel fork, made of lead. Bike's headset bearing doesn't sit quite right at the bottom for this older fork and steerer only long enough for 1 stem bolt to clamp... so not properly rideable yet... but.. frankenbike is born and doing baby crawling.
only ridden gently up and down the street as the headset and stem aren't safe for much more...but the new geometry feels good. stock steering setup felt "twitchy" , as you'd expect for a city bike. This now feels "about right for gravel". Bars will need to go up and forward for my posture. And, its massive frame triangle for a days worth of stuff.. takes my biggest frame bag with room to spare...happy so far.
For the record, there is nothing fancy going onside the headtube of this bike. not easy to photo - but its just a hollow tube. Couple of cables in there going to the TCU from the motor, but they are protected by a plastic cuff.
It's significantly larger internal diameter than that of my older non-e city bike that I pinched the fork from.
now I need to go learn about headset, headtube and fork sizes and types....not something I've been into deeply before.
Yeah, definitely don’t ride it for real until those bearings sit properly and snugly in the tube. I don’t know exactly what you’re dealing with, but you probably need a new race at the bottom of the tube to make the thing fit properly. Or, maybe there’s some kind of steerer tube sleeve that can be incorporated. Best of luck.
BTW, I’m not a Specialized wonk, but I think what you’ve got looks good!
bit of reading and learning about headsets. Seems that the stock fork is 1 1/8" all the way down, and has a shim on the crown to adapt to 1 1/2" sizing on the bike. The current crown bearing in the bike expects a 1 1/2". Implying I can either use another 1 1/8" straight fork , with another shim, or I can use a 1 1/8" to 1 1/2 tapered fork without shim.
the fork I bodged in doesn't have a shim on top, I suspect that older bike is 1 1/8" at the crown bearing. hence the wobble. don't worry I'm not riding it.
time to work out what to buy! Seems like I will have lots of options as either of the common types will fit and I don't need to go super low travel - 60mm seems good geometry.
Superb work! Fascinating to see the ol' Vado with the sus forks. Didn't realise you were a tall lad, so funny for me (medium size, 5'10") to se such a massive triangle. Looks like it'll work. If the budget stretches to a lightweight suspension it will look and feel great I think.
What tyres are you going to fit?
Also worth tweaking the gearing to go with the front sus off road gravel bike/mtb feel. I've got a 36 chainring on the front and went 11-46 on the rear from stock 44T and 11-40 (i think) makes the steep Dartmoor hills much easier and kinder on the motor as I can spin more, less feeling the motor is grinding.
going to run 10-52 rear. 38 or 40 front. AXS. I prefer to spin and have legs do most the work, motor for help when nothing left (or I my old back injury causes a leg spasm, which can happen, then I am on 1 legs worth )
I'm a rugby player shaped ape. weight to match. Only 6'0" but really long legs and arms in proportion to torso, and very broad shoulders. Not at all the "roadie" shape!
Teravail Rutland are the favourite, I've been running those at 650b/47mm on my Creo and like them. Offroad Grip is good, rolling resistance on road is pretty good as well. Want to go as large as poss on the width.
Fork, am currently looking at the Suntour GVX 60mm as I need an enormous un-cut steerer length for it to work - bike's head tube is tall. Long chats with AI telling me that the rockshox and fox offerings aren't long enough. MRP Baxter also recommended by AI but they don't seem to actually exist to buy.
Gonna stop resarching and go ride a bike now ;-)
Yeah be careful with AI, I was asking questions about a bike on ebay and it told me a downright lie, which I corrected and it said of course! You're right! then immediately got it wrong again. Have to double check stuff. Teravail Rutland look good. Your issue on the back is the stupidly low seat stay bridge. I've got 44s and its fine but above that seems tricky. Years ago a member on here in California successfully went 650B and got wider clearance that way, ideal for their desert trips.
Its Salter Fell in the Forest of Bowland. I did it on the creo. Was going very slow by the end as my hands were in intense pain.
Came back from that trip deciding to do "need another bike" research.
Canyon Grizl:ON with Rudy looked possible, until I found they use a non-standard headtube 1 1/2", so I can't get riser stem to work... very few aftermarket stems in this size.
You are way deeper into modding than I will ever get, so I only have a few tangential points to add just based on riding experience.
My unscientific, back-of-the-envelope assessment is that the road you are riding on is significantly more challenging than the road Stefan photographed, though Stefan may be riding longer distances and faster. The Grizl: ON CF 7 could manage those roads, but it would be ugly, and only practical for short distances. IMHO, the limiting factors would be that 40mm is not QUITE enough travel and the riding position is shifted too far forward.
What the Grizl can do is short segments like this, on surprisingly slippery/sandy terrain with grades up to 19%. In other words, some ruts that are a bit deeper and terrain that's steeper, but not the extended rock garden:
Stage 3 osteoarthritis here, so a few miles of this is hard on the hands-- but not miserable, could still play guitar the next day.
Very good point. I have found AI to be terrible for bike parts and cameras, any commercial mechanical instrumentality. I asked it yesterday where a first gen RX100 stores video files, and it told me the camera didn't have any video capability. So it was not only wrong, it was wrong with great confidence. For medical stuff, where it gives citations you can check, I've had a lot more luck!
I insist a proper e-MTB would be the right e-bike to be ridden in a rocky terrain. First, 2.6" lowly inflated tubeless tyres. Second, full long travel suspension for maintaining the traction. Third, a proper dropper seat-post for descents.
Once, I rode my Giant Trance E+ on a violent descent on the rocks. The vibration was as strong as it threw my pannier off the bike and the impact damaged my expensive camera inside. As I finished the ride, I found the suspension had been all locked, and it were only the DH tyres that helped maintain the traction!
While that trail turned out to be impossible for my big Vado.
The same mountain for both e-bikes, different years.
You missed the bit where he said he has 30 miles of road to do before he gets to that ancient rocky Roman road.
don't worry I will not be buying a fork off AI numbers. I hate the term AI. Its Machine Learning got a lot bigger (I worked on it a bit 30 years ago). If the machine learns wrong info , it has no "intelligence" to say , "hang on, thats a stupid conclusion / there is contradiction in your data" etc.
I wouldn't want to do that trail in Stefan's photo on a fully rigid. It would work on an full-suss emtb obviously. It should work with just a short travel , upright geometry front suss though - there's no "big hits" or "gnar" there. the question for me is what is the overall route? If its a link between red or higher grade singletrack - you'd be on an mtb anyway. If its no worse than that, or interspersed with road segments - thats where I think of "gravel". I know gravel means different things to different people... it gets philosophical almost!
The roman road I mentioned is this https://www.komoot.com/highlight/453512. There's a large amount of well surfaced road riding as well to fit it into a decent route. https://www.komoot.com/tour/2988993281 is the actual route I did. It would be not ideal to be on a heavy eMTB. whereas routes like this https://www.komoot.com/collection/8...dgeway-prehistoric-stone-circles-white-horses (I've only ridden part of it) are still "gravel" but you can do it with less bike as the tracks never get steep / rocky like the one thats 200 miles further north. Rigid bike would be fine.
anyway I plan to run 3 bikes now. Creo in "road" setup (rigid, road drop bar). Vado SL in "gravel" (60mm front suss, tbd bar, short dropper) setup. E-Genius as mtb (150mm full suss, wide riser bar, long dropper)
bring back the old-school hardtail, thats what I say :)
Or 26er rigids! Back as a teen in the 80s we bombed down any trail we could find. Bunnyhopping holes, like those nasty water courses that gouge little ravines across the paths that are deadly. No suspension back then, 1.9 inch tyres, canti brakes but good low gears with 3x. Great competitions trying to climb impossible tech steep paths, seated, in granny gear, and penalised for dabbing a foot, motorbike Trials style. Best fun of my life. And to get to the mountains it was 10 or 20 road miles unless we snagged a ride, but the geo on those 80s/90s MTBs and the not too wide tyres were suited to mixed riding, pretty fast and rigid on the roads. There were no trail centres, we didn't know hike-a-bike, rock gardens or single track, just carry yer bike, rocks ahead and sheep paths - which always seemed to end down in a bog god knows where and then had to carry the bike back up the mountain! No GPS either just soggy maps.
This photo is halfway up Galtee Mór, ( the top is to the right, here facing the saddle between Galtee Mór and Galtee Beg) over 3000ft and the third highest peak in Ireland outside Kerry (Kerry has the highest mountain, Carrauntoohil 3407ft and several other peaks over 3000. We did attempt Carrauntoohil one memorable summer but the main route has a rock face scramble called the Devil's ladder, just impossible up or down with bikes so we left the bikes behind a rock and climbed on foot.)
Here in pic, we're trying to figure the best route to the top, (no paths!) find the most rideable bit, but most of it we ended up carrying the bikes anyway. After a sandwich at the top, we lowered our saddles and bombed straight back down! Just great craic. You'd rarely meet another mountain biker in those days.
