I'm shopping for a handlebar adapter for my 2022 Homage. On the vendor's web site it says the adapter will not work with a Homage 4. How can I determine if mine is a 4? Thanks.
If it’s a 2022 model, there’s a good chance it’s the original Homage rather than the newer Homage4. One easy way to check is the frame and battery design: the Homage4 has a fully integrated Bosch PowerTube battery and the distinctive one-piece frame/step-through design that extends into the rear rack. You can also look at the model name on your purchase paperwork, frame sticker, or serial-number information from Riese & Müller. If you’re still unsure, post a photo of the bike or the frame label and someone here should be able to identify it quickly. (propelbikes.com)
Well, that describes my Homage to a T: fully integrated Bosch PowerTube battery and the distinctive one-piece frame/step-through design that extends into the rear rack.
Frame number WRJ2HM4M4LD100744 I assume the HM4M4LD in the frame number identifies it as a Model 4. Here's an image of the adapter I'm looking at. But they specify it won't work on the Homage 4. It looks like a pretty good setup. Does anyone have experience with this adapter.
The manufacturer of the adapter said it wouldn't fit the Homage 4 because there were cables routed through the head tube area that woul interfere with the adapter. On my Homage, there's a small rubber plug in the opening that I believe was previously used for routing a cable or two. I've decided to order the adapter and take my chances. The rubber plug is minimally protruding from the hole it covers, so I don't think it will be an issue.
