Re-greasing the Ultra motor...is it time?
So we are currently in a very cold stretch here and I find no enjoyment in layering up to ride.... That and the MUP is a sheet of ice.
So I opened up a new Quiet Gear Ultra with just 100 miles on it...Note, I don't find it to be any quieter than my 2022 motor.
The amount of factory grease seemed adequate but was the same yellow seen before but had mostly black'nd in color and quite frankly looked burnt and wasn't easy to clean up.
So cleaning it up was tedious but with patience doable
Put back approximately the same amount of Cornhead grease and about the same as I had used on the 2022 motor when I used the Mobile SHC100
I found the Cornhead very hard to work with and to be neat with. It has a very tacky property and it's like working with snot.
This also lead me down the path of making a mistake. Not wanting to have two very different greases in the motor I also lifted the main large gear to lube the pawl clutch with the cornhead. And though I used as thin a layer as possible.. When reassembled the pawl clutch didn't work correctly due to the tackyness of the grease. Luckily I bench tested it and found out then. So I cleaned it up again and used some Mobil SHC100 which didn't give me the same problem. The greases are far enough apart so they shouldn't contaminate each other (hopefully)
This now done its still not favorable outside to ride and the temperature still hasn't risen above freezing. Hopefully it'll change soon and I'll get out in the next week.
First impression.. If the cornhead doesn't provide a much quieter motor, I'll stick with the Mobil.
I feel for you. I'm hating this weather. I don't mind bundling up. I use fur lined pogies without gloves. I just hate ice. Do not want to go down on ice.
Curiosity got the best of me so I ventured out for a short 5mi ride.
The MUP is still a sheet of ice and the streets have enough ice melt salt on them to start your own Dead Sea... But at least the temps made it to 40° this afternoon for the first time in too long.
This said and my first impression... I'm not experiencing the Quiet Gear nor Corn Head Grease miracle.
Probably measurably quieter but no where near what I would consider to be quiet motor. If you've ever riden with a BBS02B... Now that's near silent.
I'll give it a few more miles and see if things get quieter with break in like they did when I initially tried the Mobil SHC100
I may then open her up to check migration and possibly top it off as I've seen many on here with cornhead grease pics and much more grease was used.
Hey @JRA ... You speak of only using a tblsp and I'd guess that's about what I used.. How do my pics compare to the amount you used?
Sounds to me like you may be experiencing premature coagulation as a result of greasing your own bafang ;)
No one would know better than you Black Hand.
What's truely amazing is that you taught the dog to reach all those tricky bearings that you so desperately tried to reach but just couldn't. 🙃
SO I'll ask again,
What do you use to clean to clean out to old grease and WILL NOT harm anything inside, like all those electrical boards/wires etc?
Tia
SO I'll ask again,
Tia
Paper towels, a cloth rag and a small plastic brush.
Alcohol wipes to finish up and for anything electrical that may get grease on it.
Several e-bike shops in Australia recommend the Mobil 28 grease. It has an NLGI of 1.5 per the data sheet, wide temp range with very low starting and running torque (low drag).
So an update on the Quiet_gear motor using Cornhead.
@ 450mi total and 350mi since the initial Cornhead application the motor still had an annoying whine (IMO)
Decibel wise it is probably quieter than my other standard gear Ultra Motor using the Mobil SCH100... but again, not what I would consider a quiet motor. As it's breaking in it is a little better than new and the first few rides after the initially Cornhead application.
It's raining here so I used the time to give it a quick inspection. The grease seemed OK and none had made it's way to the controller....
.... so I decided to add some more to see if it would make any difference. Not as much as @Tom@WashDC used.. but significantly more than the tablespoon that @J.R. uses.. which was about what I initially applied.
Like the first greasing I removed the 2 smaller gears and packed all the teeth in the underlying gears, then the upper gear teeth. Put the gears back in place and then I packed the space between the gears and the casing.
This tacky snot grease is so annoying to work with.
First impression...
The first 1/4mi the motor was near silent...but then it slowly got louder as the grease liquified and spun off the gears. By the time I reached the top of the 3mi hill at the start of the MUP, averaging about 14mph and drawing >200w the motor whine was back. Somewhat less than before and at a lower tone but definitely audible. The next 4mi it pretty much stayed at that level so I queued up the Soundgarden I have on my mp3 speaker and some Jesus Christ Pose made the motor whine disappear 🙃
On the way back pretty much the same and I could hear the motor between songs.. but I can say definitely less noise than before this repacking. I'd say I have about 1/4 of the 10oz cartridge in there.
Total ride was 24 miles
Hypothesis... For the cornhead to make this motor really quiet, you'd need to pretty much fill in all the space in the gear box section so that when it liquifies under mechanical pressure from the teeth, the grease that is not being churned and is in the static solid state will hold the liquifyed grease on the gears.
How it's greased now is better than stock but far from what I would call silent.
My perspective may be tainted by my experience with the very quiet BBS02B
I'll add... the Quiet_gear motor is a fugazi
So with 750mi on the QG motor and 650mi since switching to Cornhead the motor was still whining annoyingly.
I opened her up and packed the gear box with cornhead as this was the only thing left to do and there was no sign of migration into the controller area. In doing so I didn't see any signs of wear but I did notice that the top of the gears (when looking at it in it's mounted state) looked almost dry of grease. I'm assuming the grease under load liquifies and flings off during operation.
Since doing this I've put another 150mi on it and now I can finally say that the motor is acceptably quiet though still not silent. Very quiet under 250w but put her under load and you can hear it.. though now at a much lower level and at a lower less annoying tone.
I think my initial hypothesis in my last post is proving true. Due to the thixotropic characteristics of the Cornhead the gear box needs to be full so that as it liquifies.. it has no place to go but back on the gears.
Honestly I don't see how a tablespoons worth of this grease can be sufficient as I'm using 8 times that amount now. A little less than 1/2 the tube.
Now my only concern is my original.. migration into the controller area... but since the grease is thicker in it's static state I believe it will contain itself to the gear area as it has so far.
Still not sure if I like it better than the Mobile SCH100 in which a heavy tablespoon is sufficient and showed no gear or grease wear after 4000mi.. but I'm willing to experiment further.
Y_Viscosity_MV
A quick update.
2,250mi on the Quiet Gear Motor and 1,500mi since filling the gearbox with Cornhead grease and the motor is running noticeably quieter and smooth.
I think between the motor gears breaking_in and after trying less and now filling the gearbox with the Cornhead are the differences. Nice low tone and hardly noticeable on the low load flats. Flying up hill it is a bit louder but still very acceptable and at a much lower tone/volume than before.
You can't expect 1000w/160Nm to be silent...and I'm more than happy with the results.
One more update on the Cornhead grease.
4,750 mi on the motor and 4000mi since the last inspection. The motor is running quiet and smooth.
I see no signs of gear wear or grease migration into controller area.
Top'd it off with another tablespoon around the gear teeth and closed it back up.
I'm ready for the riding season
I’m about to grease mine for the first time and not sure which grease to use. Does the corn head grease blacken?
In my experience so far... A little.
The Cornhead grease is excellent at making the motor quiet, but you need to fill the gear compartment otherwise it flings off. It's an annoying grease to work with...but it works well.
The Mobil SCH100 is excellent at preventing wear and is neater to work with as it stays in place without over packing. It does help quiet the motor a little, but not as much as the Cornhead
I prefer wear protection over noise reduction. I might go with the Mobil SCH100. If the CH grease is starting to blacken it might be breaking down.
Pic of mine after first opening after 3600 km’s. Seems to have been well greased from factory.
Yeah that's more grease than I've seen on most post factory inspection.
I'm torn between the two greases I've tried on different motors as they both seem to work well. Regressing is easy enough so even if the CH doesn't last as long, it's not a deal breaker. Some here swear by it. The SCH100 is more in line with the factory grease.
What year is your motor?
It's hard to be sure as you can't see the entire rotor gear.. but it looks to be pre 2023 with the 9 tooth. Starting in 2023 they start using a 15 tooth and the motor is " supposed to be" a little quieter.
I have one of each and though 15t is technically quieter, it's negligible. That said it's very quiet now using the Cornhead grease.
That, that said... No where near as silent as my BBS02B
My motor has the older 9 tooth gear.
I'm not really concerned about the noise though, so I won't be changing gears or using a particular grease just to reduce noise.
For what it's worth I AI'd the topic on a few greases I was considering and this is the ranking it came up with based on a few factors I felt were important.
Grease
Protection​
Quietness​
Efficiency​
Gear Cling​
Anti-Channeling​
Overall M620 Suitability​
Mobil Aviation Grease SHC 100
10​
10​
9​
8.5​
8.5​
9.5
INOX MX8 Extreme Pressure Grease
9.5​
9​
8​
10​
10​
9.3
Mobilith SHC 100
9.5​
9.5​
9​
8.5​
8.5​
9.2
John Deere Corn Head Grease
9​
9​
7.5​
9.5​
10​
8.9
Liqui Moly LM47 Long-Life Grease + MoS2
10​
8.5​
7​
10​
10​
8.8
Mobilgrease 28
8​
8​
10​
7​
7​
8.3
I definitely wouldn't change the gears unless they were worn and needed to be changed.
And I can tell you from personal experience that Ai is full of s*it 🙃
The SCH100 definitely has better gear cling than Cornhead.. and it's definitely not quieter than CH.
I agree that SCH100 gives excellent protection.
The higher Anti channeling rating of cornhead is deceptive - N/A as the grease is Thixotropic so the gear box needs to be full to keep grease on the gears
The CH may be more efficient that the SCH100 as it's thinner to start with and thins further under mechanical pressure... but I think this is probably negligible.
Just my 2c
Did you use the same quantities of SCH100 and CH?
Efficiency is not just about viscosity. I clingier grease will have less efficiency. I slicker grease will also have better efficiency.
The aviation SCH 100 is also a good flowing grease at colder temps.
It is a NLGI Grade 2/ISO VG 100 grease having the cold-temperature pumping resistance of most mineral-oil NLGI Grade 0 greases.
At first, yes. But shortly after checking the CH it had mostly flung off. That's why you need to pack the gear compartment. In use it's like an oil.
In general oils are better for gear boxes, so that's why the I think the CH works well. Think of the motor and transmission in your car.
But imo the SCH100 is an excellent grease and the application isn't technically a sealed gear box. Probably why Bafang uses the grease they do.
The CH is kinda a hack... but it seems that those that have tried it are very happy with the results.
Again... I'm kinda torn as I really do appreciate the quiting effect of the Cornhead.. but the SCH100 seems to be a more traditional approach with excellent results.
