Clean Custom Conversions
I have made three Pashley Prospero gravel bikes electric. They come in a bunch of colors. Click here to view the bike: https://www.pashley.co.uk/products/prospero?variant=53488110272887 There is also a Youtube series where you see a factory tour and they make a bike from tubes to ride. These are made from Reynolds 631. I want to convert a Gov'nor with a double top tube.
Check out the internal brakes. It needs Hurricane 47 black tires. The rims are the same custom color as the frame. I would use polished cranks, paint the motor silver, and reuse the chain guard, so it is polished.
I dare you to electrify a Rivendell Atlantis, drive it down to Walnut Creek, and ask Grant Petersen to autograph it for you.
Bafang BBHD's are notorious for messy wires and connectors at the handlebar. I cheated. I installed a phone bag and used a blade to cut a slit at the front of the bag. I then grabbed all the extra wires and connectors and jammed then in the sack one at a time. Just like that, they vanished.
AMC had some odd looking cars in the day! Between the Gremlin and Pacer, not sure which was more odd
Some were not too bad looking either - a hatchback Hornet or the AMX/Javelin were not that bad. But that "Snot" green or the vibrant lime paint options would be pretty bad on any vehicle.
This bike was so clean, I cheated again, I admit, and hid the display wire inside the handlebar. I am a flagrant cheater. But the old lady bike Huffy Target curser has a 90Nm, 750W motor and can pass a $15,000 350W bike from stores. Smoking Vados. I smoke two Vados in the morning, I smoke two more at night. I smoke two in the afternoon, it makes me feel alright. When an old lady on a stealth Huffy Puffy passes a Specialized Lycra weekend Dentist poser, it makes me happy. Does it even look electric? where the F are the wires.
Very nice (cheating good).
You've got to start painting those bottle batteries a few different colors ... even just white would help on this one.
Nice hide of the wires in the handlebar. Did you run the wires under the grip and into the end or did you drill the bar? If the later you need to be careful as drilling the bars can weaken them. It may not be much of an issue for an urban bike and someone who isn't too heavy but any situation that can put a lot more pressure on those bars can stress the weak spot at the drilling site. I hid a cycle computer's wires in aero extension bars on a road bike. The wires were very small so only required a small hole but the bars were small diameter aluminium and after a few years failed when I really torqued on them when lifting the bike.
That single speed Huffy Puffy coaster brake bike had a heavy steel bar. I drilled two 4mm holes. One by the quill stem and the other just below the display. It was for an older lightweight female rider who would not be out of the saddle or up pulling on the bar. Another similar bike was given to me for fixing a flat. She only rode it once. I sold it two days later for $2K to an artist who said it was the most beautiful bike ever.
I rode this Gary Fisher cargo bike from south SF over the GG bridge, non-electric and with hills, headwinds, to Larkspur and then took the train to my shop. I converted it with a TSDZ2. A friend said that it reminded her of Eliot's bike in ET. So, I put in an ET to make it more aero. Her husband would not let her son have a doll. So, I gave him ET. It is so ugly the dad did not object.
I was going to ask if it had steel bars.
I was thinking that years ago (70s into the early 80s) as index shifting and such was coming in there was a real movement to routing brake and shifter cables to under the tape on the drop bars. It was really interesting to find different ways of camouflaging the ridges from the cables. Then we started seeing bars dimpled for the cables.
Mountain bikes led the way back to open exposed cables since the bars generally aren't wrapped. Ebikes have only made this worse, and don't get me started on the wring of the Cycle Analyst - due to it's incredible versatility it contains wiring for all sorts of separate connectivity and all that wiring hangs out under the unit (thus Grin supplies the inelegant but effective velcro "sock").
It would be nice if there was a simple, inexpensive and flexible conduit for wiring that was small and inconspicuous enough to use underneath an MTB style handlebar. There are some examples that are intended for use on the body of the bike but I've never seen anything appropriate for the handle bar area except for flexible wiring wrapping products.
The steering bars on the recumbent trike I am working on are vertical. The display would be sideways. I just cut the curve out of a drop bar with a pipe cutter and used a accessory extender mount so now the display will be horizontal. That bike is a PITA.
This Boda Boda has a white wire to the display. I cheated by using white heat shrink. The basket liner was sun faded. I restored it using DOT 5 pure silicone brake fluid. Then I cut the top off a cycling water bottle and used gasket maker to attach it to the top of the battery.
I finished the recumbent trike. What a pain. The long runs meant that I needed to make my own wire looms of a thicker gauge. And splice a bunch of stuff together. It just needs pedals and programing. I want it to launch smoothly then ramp with torque and cadence. This is from today but the camera battery was dead for over two months so the timestamp is off. I used a chunk of drop bar to make the display horizontal.
^^ How’s it coming, Pedal?
@Chazmo, I did that one.
Oh, man. I woke Wednesday with a swollen shut left eye and a rash on my left forehead. Its ocular shingles and risked blindness. I am being treated but it has taken me off my game for a few days. It is starting to get a little better and I will be back on by Monday. I only have two smaller jobs today after a Dr's appointment. Everything has been pushed out.
Oh, I know. I guess since I saw the “error” post you were saying it wasn’t working. Did I misunderstand?
Anyway, hope you feel better soon! Love looking at these custom builds!
The error was that I needed to use Google Lens to identify a part, a specific battery with a built in controller, and to source it. That requires posting it on a public website. Then I couldn't fully undo it. This morning I will ride a bike that I made six-years-ago. I bought it new for $450 and converted it. It is so simple and inexpensive to maintain. And just a pleasure of a town bike to ride. A few things have changed. It has a riser quill stem, a trigger shifter, coffee cup holder, and longer battery.
Not at all. It's a little harder if you're a Luddite without a smartphone.
Assuming you've already copied the photo from your camera to your desktop/laptop, just open the image directly in the Chrome browser. Then just right click to get the option to search with Lens.
Looks like you have a dummy chainring functioning as a chainguard on that bike?
