Another new TQ motor: hpr40
I am not familiar with Fazua Ride 60, but from you description it sounds like it has different settings and how it manages assist. On my last ride I watched the power meter and most of the time I was putting in 150W, the motor contributed 0W-10% of the time, 30W-50% of the time, 60W-30% of the time, and 150W-10% of the time. 42miles, 3500 elevation gain and the battery had ~55% charge remaining when I got home. I was riding with my wife who has the same BMC as me an her battery had 72% charge remaining. She is lighter and stronger than me so road most of the ride in eco-30W assist.
Sadly Porsche the owners of Fazua have just closed down the company laying off the entire staff it seems having bought Fazua a couple of years ago.
Thank a lot .It's confirming my assumption / estimation fpr the 290w battery .Unfortunately for the time being is impossible here to find a test bike [ Scott/Bmc/Ridley] so far we can only simulate and/or extrapolate data
Indeed it has been a shocking news and globally a very sad news for all of us riding a FazuaRide60...On other hand Porsche's Financial Result are so bad that no core business is out of scope
Had my BMC for a couple weeks and been playing around with motor settings. What seems to be working for my riding style and location follows. At these settings I can get +60miles of range with 3000-4000ft of climbing. Also suggest that TQ40 would be plenty for my type of riding. Curious to hear what others are using...
ModePower CapSupport %Pedal ResponseRationale
Eco30 W30%LowOffset bike weight/tire penalty while preserving analog feel and range
Mid60 W60%Low / Medium“10 years younger” mode
High150 W100%MediumShort-term boost for steep climbs, wind, or fatigue
It really depends on the rider and too many other factors. Here's the stat page of a gravel rally organiser who rode a Raymon Norza Pro (a carbon Bosch SX gravel bike).
63 miles, 5,082 ft elevation gain, with some 14% grade climbs, an area consisting only of climbs and descents. He rode in a Tour+ assistance, which is 45 Nm max and 300 W motor mechanical assistance max. Tour+ is a dynamic mode, which automatically switches between ECO and TURBO as needed. His e-bike (rented for tests by Bosch E-Bike to him) had a 400 Wh battery, of which he used 94% for that ride. The man is a 40-yo able-bodied rider. Given the e-bike had an EU 25km/h restrictor, I assume he rode all descents and flats without any assistance.
E-bike weight 32.4 lb.
Pinarello Nytro E Allroad, 32 pounds, HPR50. I'm still tuning.
Eco: 120w/71%
Mid: 200w/111%
High: 300w/200%
I ride about 40% Off, 60% Eco, with an occasional bump to Mid. I have never used High except for experimentation. As I get fitter, I expect to drop the Eco assist below 100.
Eco: 120w/71%
Mid: 200w/111%
High: 300w/200%
What do these numbers refer to in HPR motors?
Interesting to see how other people set and use their own assist modes — and how those choices evolve over time. I had a phase like that and could well again.
You said once that you like to go fast. So do I at times. Took me a while to figure out that that's what TURBO (my High) is for.
I resort to TURBO in certain traffic situations I want to squirt through or leave behind ASAP. Also handy on the steepest (15-16%) of the 1-block ramps so common around here.
Otherwise, rarely feel a need for TURBO. Not that I'm a strong rider. I'm not. Just that I can generally get all the speed I want from my 240W, 35 Nm, 38 lb Vado SL 1 in OFF, ECO, or SPORT. Increasingly using SPORT on fitness segments, as it somehow drags more effort out of me.
HOWEVER, suddenly thinking, "Boy, this ride is fun!" has turned out to be a clue that I forgot to back off from TURBO. And who's making the rules here, anyway?
Now I treat myself to TURBO segments just for the fun of it, battery permitting.
The first number is maximum power in that mode. In Eco, the maximum power is detuned from 300w to 120w.
The second number is the motor assist percentage. At 71%, the rider needs to be putting out about 85w to get the full 120w out of the motor. Total watts would be 191w. Anything over that is 100% rider power.
Thanks! So writing an HPR assist mode as A/B, A = the mode's max (presumably mechanical) motor power in watts. B specifies the saturation rider power Prs as a percentage of A. Hence, Prs = A B /100 is the rider power Pr needed to saturate motor power Pm at A.
I like that. The current mode's Prs can be a handy thing to know in the saddle.
Now write a Specialized assist mode as E/M, where E and M are both percentages from 0 to 100. Letting Px = the bike's max possible mechanical motor power, your A ≈ Px M / 100. At a given cadence, B is proportional to the slope of the ramp up to A in the motor vs. rider power curve.
Roughly, higher E means a lower (easier) Prs. But there's no simple way to predict Prs in a given mode. So no simple relationship between my E and your A or B.
Makes sense. However, the relationship between how hard a rider pedals, how much the motor assists, and the maximum assist power is a fundamental equation in all e-bikes, no matter how it is measured.
I am new to this but from my observations so far it appears TQ motor power is somewhat linear until the max motor watts are hit for each mode. Rider power is the input variable while riding.
Pm = min(A, B·Pr)
where:
  • A = max motor power cap
  • B = support %
  • Pr = rider power
  • Pm = motor power
That said, I suspect more happening behind the scenes than this simplified steady-state model — cadence, motor RPM, transient response, smoothing, efficiency curves, thermal limits, etc. The following illustrates the relationship for 3 settings.
I'd like to see the data behind that statement.
If you plot empirical mechanical motor power Pm vs. rider power Pr on a Specialized Vado SL 2 mid-drive, you get a ramp and flat geometry with a ramp of constant slope. You see this consistently in the excellent field work by @mcdenny in steady-state riding.
This screenshot shows representative SL 2 data from the post linked above. Official Specialized documents imply that all of its mid-drives have this Pm-Pr plot geometry.
And @apctjb above has reason to believe that his TQ's Pm-Pr plot has this geometry as well, though we haven't seen his data.
I'm prepared to believe that this Pm-Pr plot geometry is a common in mid-drives. But not prepared to say that it's universal.
Complicating all this is the reality that we have no idea how manufacturers who use these ramp-flat relationships choose their actual ramp slopes and flat heights.
For example, there's no simple relationship between Specialized's slope and height choices and the E/M settings @mcdenny tested on his SL 2. His data shows a clear cadence dependence in the ramp slope that we have yet to understand.
No recorded data, just observation of power while riding which is imprecise at best. That said it appears to be a somewhat linear relationship between rider power and motor power until max motor power setting is reached.
