New mirrors day
And my Hafny mirror,..
I didn't use that mirror for long before I replaced it.
I'm sure it would have broken if I ever dropped the ebike.
This is one of the times my ebike fell over and the West Biking mirrors survived,..
Those failed twice for me - plastic is not durable and prone to cracking unfortunately. Great they work for you! They are nice mirrors.
Yeah, not sure why our experiences have been so different. I think our bikes and usage are pretty similar.
Glad the ones you switched to have held up.
,.. E13 broken at the same exact place before switching to current metal ones.
Do your new metal ones have an adjustable pivot at the clamp?
My plastic version was locked in one position and I had to almost completely remove the bolt before the arm would rotate out of the way.
I would have glued a piece of an Allen key into the bolt head so I could loosen it easily, but not if it needed half a dozen full rotations to loosen it enough.
No. Those claps are re-used from my old Hafny mirrors and pretty much same as yours. So yes, adjustments are quite tedious to do, but I don't need to do them often. The clamps from my mirrors were very bulky to be used on my quite small and busy handlebars, so keeping the old clamps was reasonable compromise which worked.
Well, probably matter of terrain and distances. Do you ride outside of smooth pavement? How many miles you have with these mirrors so far?
New mirrors are all-metal, not much to break there. Main challenge was mounting and limited adjustment options.
I couldn't see past my jacket with mirrors tucked in.
They needed to be 5-6" out beyond the end of my handlebars so that I could see behind me.
These worked best for me.
I had to mount them at the ends of my handlebars, but they were spring loaded so I could easily fold them out of the way to get through doorways.
I fell on them a few times and they didn't break, they just folded out of the way.
View attachment 209249View attachment 209250
I managed to get my Hafny mirrors mounted in the same way, but they wouldn't fold out of the way without undoing the bar bolt every time.
That was a PITA.
The way you have them set up... You're probably getting better range with an improved lift to drag ratio 🙃
But if you set them up more in board, there is no reason to fold them in repeatedly.
I much prefer bar end mount as my handlebars are crowded with accoutrement.
These fold out (or get whacked) out of the way without issue.
And if you only snug the adjustment screws they still hold firm but allow for easy adjustment on the fly.
About 16000 miles. The majority are suburban/urban commuting but yeah, the bike has seen a fair bit of rail trail, logging roads, and single track as well.
Lol,.. Yeah with me sitting up straight with no hands on the handlebars and my mirrors sticking out in the wind, I wasn't very fuel efficient. 😁
I tried that, and I just couldn't see past my jacket for some reason?
I don't know why I seem to be the only person that had that problem?
I remember that my motorcycles had the mirrors sticking out quite far as well.
I was looking at the bar end mount version, but I still couldn't get the mirror out farther.
The bar end is one piece locked at 90° so I still couldn't fold the mirror out far enough.
If that mount was able to fold out, it would have been Perfect for me, and I tried to find an adjustable bar end to use but didn't have any luck.
How much further out do you need?
Just a couple more inches.
If that attachment arm went straight out instead of up at 90° that would probably do it.
I had about the same mirror position with my Hafny mirror, and it wasn't quite enough.
I could sorta lean to the side a bit and move my arm to see directly behind me, but that was a PITA when I like to check my mirror every few seconds.
I hate those bulky things that stand out way too much makes a bike that looks like a motorcycle.
I never cared about what it looked like, and I wanted a Large mirror that was just a tiny bit convex.
With those tiny 1"-2" mirrors that are too convex I can't see a car coming up from behind until they are 10 feet from me.
If those were the only option for me, I simply wouldn't use a mirror, and just rely on head checks.
If a mirror isn't practical or functional, then it's safer to not have a mirror.
Thats more than mine, but somehow their mirrors never lasted longer than a season for me.
EDIT:
That's wrong, I needed more than a couple inches.
The only long reach bar end mirror that I could find with an adjustable bar end clamp was this Busch and Mueller that I almost bought but then switched to my helmet mirror.
And, my Hafny could see past my jacket but I could only install one and still be able to get it through my doorway.
When I had only the left mirror installed, the wind would push on the left mirror and steer my ebike when I rode no-hands.
