Anyone converted their Turbo Vado to tubeless tires?
Get a Schwalbe Tire Booster or the Airshot which is the original brand. There is also the Topeak Joe Blow Booster tire pump. I use the Tire Booster with a Makita electric pump. I do have a compressor but generally if you need the compressor something is not fitting right. Edit 2. Don't do this anywhere that does not have a hard surface and easy to clean or over a large plastic sheet. Do not wear your favorite jeans no matter how good you are.
Get a Schwalbe Tire booster or equivalent. There is also the Topeak Joe Blow tire pump.
I have the Joe Blow — excellent all-around floor pump! I've only had occasion to use the reservoir feature twice for seating tubeless tires, but it worked well both times. No room for any compressor in my small garage.
One easy way to see how well a tire will seat is if the bead sits on the center of the rim, it will be hard. I have some Schwalbe tires that the bead is as wide or wider than the tire, and it seals with just a regular pump, but it makes it harder to get on as the first side likes to come off while trying to get the second on.
I edited my post but I use a Makita battery air pump with the booster. I checked the prices of the Joe Blow Booster after I posted. I think the Airshot is the cheapest way to go if you already have a tire pump..
Allan, to prevent a potential mess, I seat the tire to the wheel before adding the sealant. The sealant can be added through the valve, with the valve core removed, with the sealant small plastic injector (Stan's), the short tube (Orange Seal) or injector tool (Park Tool, or alternative).
Your comment reminds, me...back in 2015 when shopping for my first full suspension MTB, at a major local bike shop, before my test ride, they needed to top off the tires. The shop employee, over inflated the 2.3" tire and SPLAT!, sealant all over the showroom floor....whoops! I didn't even know about sealant at that time! I was far enough away, nothing sprayed on me. never had a blowout myself, setting up my own tires, at home...knock on wood.
ya I tried it once adding sealant before seating the tire what a pain. its better on bigger tires.
I seat the tire first then add sealant. I've tried various injectors that always clog and spew sealant. I currently use a Straz Components sealant funnel and add sealant 30 ml/ 1 oz at a time with a dip stick to push fibers through. I check my rear tire sealant about every three weeks and the funnel is the cleanest way to add an ounce or two.
I use the airshot. small, light, silent (no moving parts!) and it has never not seated a tubeless tire for me. it’s a little scary opening the valve and hearing the BANG POP BANG of the instant inflation and seating, but works every time, at least on my modern tires and rims.
i never clean old sealant out. that just means you’re not riding enough. never had a tire last long enough to need to do so!
I own it all including tubeless rims, the booster tank, rim tape, a big electric pump, several tubeless valves and tubeless folded tyres, not even mentioning a CO2 inflator or sealant. Still, I chose simplicity and comfort of inner tubes instead of the struggle with tubeless. You could say "Stefan, you're a lamer" and you would be right.
However, my brother Jacek is a different person: a skilled bike mechanic (to the level of wheel building) who has perfection ingrained in his mind. There's nothing difficult for him, he would learn anything, he never leaves any work half baked or unfinished, and he owns a heavy duty compressor. He had succumbed to the tubeless hype and installed the tubeless on his Marin bike. To go back to the inner tubes soon. "I have given the tubeless up after the sealant sprayed through the spoke holes". Well, he is not a guy who wouldn't know how to install the rim tape properly!
Tubeless tyres are great. Until they aren't.
Stefan, you and Ollie can make a Tube Team. I get it. But I am also a bit surprised, as I am a mostly incompetent mechanic and have employed tubeless since my first tubeless set up with with my Santa Cruz Tallboy in 2015. and on a scale of 1 to 10. I rate my own mechanical skills at a solid 6.75 of 10. I have not been challenged with tubeless repairs since 2015. Sorry if I am repeating myself....I had a puncture on an organized 65 mile ride Gran Fondo in Sonoma, and at about mile 50, with my 32mm Conti GP5000, tubeless, I got a puncture. Repaired on the spot with a Dynapug.
Days later I saw other tiny metal shards in the tire.
Ed, I had some inner tube punctures this year (something that wouldn't happen to me for years before). The most critical day was the one when I rode into glass bottle shards on a Warsaw bike-path. (A very, very rare thing as we tend to keep our environment clean in Poland). I was losing one inner tube after another (taking more of them from a friend who was together with me). Then I got on a bus and rode to a sports store that was miraculously open on one of rare "trade Sundays". Even there, the bad luck continued! It turned out there was a shard of my tyre lever that got inside the tyre on the previous repair! That was a really bad day...
On one of my earlier rides, I lost my faith in Schwalbe Aerothan TPU inner tubes. It looks the valve connection with the tube is apt to fail there!
I do not say tubeless is absolutely wrong, no. I was very happy with tubeless on my former e-MTB. The setup saved my bacon on a ride in a West Pomeranian wilderness in summer 2020. A piece of quartzite made a hole in my front tyre. I even had no tubeless repair set with me! Eventually, the "milk" could seal the hole, I could reinflate the tyre and continue my ride. Owned I an e-MTB still, I would certainly maintain it tubeless. I simply see no reason to fight with the tubeless on 42 mm gravel tyres.
A gravel road made of quartzite...
A big hole closed by the sealant.
Stefan, it is so great that you ride so much, to have stories!! Love it! I am trying to do that myself.
Flats happen. Regardless of tire set up.
Your post made me realize I have so many unused tubes that I need to hand over to friends. I have tubes from my skinny tired road bike which is only used indoors now on a trainer, so 25mm tubes, and tubes for the MTB with 29er. I did find a cool tube which covers whee/tirel sizes...1.50-2.40. Thanks for the reminder, I need to collect all of my tubes and pass them out. they are only 5 yrs old at the most.
My post would be better with a picture, but my rear mtb tire looks like an alien carapace with white blood survived a frag grenade. After 1,200 miles on my Trek Rail emtb of hard single track, forest roots rocks and gravel, the tires are used up. There are perhaps a dozen tiny punctures slowly weeping sealant yet the tires still hold enough air for 20+ mile rides. I refresh the sealant one a quarter, which is a 5 minute process with a plunger. The old girls loose about 3lbs or pressure a week but no big deal. I have a small battery powered pump at a preset pressure, snap it on and 30 seconds later am good to go. There is a new set of Maxxis Assegai rubber hanging on the wall, ready to relace the war torn factory tires.
Zero flats, 16-17 psi front, 19-20 psi rear.
Tubeless for me, 150%.
I get that leakage when I was using CO2. I thought it was because of winter, as that’s the only time I need it. But it was the co-2 once I went with the electric pump, it stopped being an issue. Even though my sealant is rated for co-2 and I would replace it when I got home.
So cool to shop via bike. I know many of you here use you ebike as your main mode. I am using mine more for everyday things. Gas prices are crazy here. Near $7 per gallonView attachment 209727
I love when you show pictures of your creo- that colour green is fantastic. And I think with the all black tyres the rack looks good. Didn't expect it to on the Creo!
