I bought a Grizl:ON CF 9, AMA
How do you control the motor? Is there any remote or road handlebar buttons?
‘The top tube LED controller has two buttons, one for motor power and one for battery power (bike on or off). Single click of motor power mode increases power whereas a press and hold is decrease.
This can be a little annoying but Bosch makes a Mini Remote that can be fitted to the handlebar (two sizes, order the correct one for drop bars) that allows you to change the motor power quicker.
I also have the remote paired to the Purion 400 screen I fitted onto the bike (I prefer my Garmin Edge to the Kiox but still wanted a small screen).
I just took delivery of a Grizl:ONfly CF 7. It's my first Canyon, first gravel bike and first eBike. Based on the reviews, specs and sale price, it was a deal too good to pass up. When ordering, the hardest part was determining my size. I'm right between a medium and a large. I went with the medium.
I unboxed and built it up today. It's on the charger right now. The rain however, means my first ride will be tomorrow. My "in the basement" perspective is that the handle bars are about an 1" to an 1 1/2" too low. Now this is just from sitting on the bike in the basement. Maybe I'll get on the bike and it'll fit like a glove. But if it doesn't, what's the best way to raise the handlebars?
The stem is all the way up with the spacers below. Canyon says it's the only stem they sell for the bike; they don't offer the stem with different angles. They did say that any stem that fits a 1 1/8" steerer will work though.
Has anyone had any luck raising the handlebars on a Grizl:ONfly?
Thanks.
Swap in a standard road stem and flip it if needed. What part of MA are you in?
I was wondering if a standard road stem would fit. The base of the stock stem doesn't appear to be round. If a standard stem will fit, that's a no brainer. Thx.
I'm in south central MA, Uxbridge.
Thanks.
Hey, Leon! I just got a Grizl:ON CF7 myself last week and I'm having a great time with it! I agree that it's a phenomenal deal at 4K. It is also my first gravel bike, though I've had drop bar acoustic bikes and eMTB and acoustic MTB and kind of a hybrid, raised-bar-with riser backsweep setup.
I'm 6 foot 3/4 inch and weigh 155 pounds with a 34-inch inseam, and went with the Large, which did fit me like a glove. (I also seem to have lost the spacers, which is a bummer-- I rode the bike home with a backpack for the charger and tools, but had to leave a few things in the box to pick up later. I think I left the spacers on the counter at REI, I'm going to call them today.)
Question: Do you have experience riding on the hoods? I did not. I have stage 3 osteoarthritis in my metacarpal joint, at the base of both thumbs. The pain is basically gone, because riding on the hoods, the pressure is on the other side of my hand, more towards my little finger. The lower riding position is a little hard on my lower back, but the pain above my left hip is like a two or a three, while the pain in my hands was a 6 to a 7, and was in both hands, so overall, it's a huge win for me. Factoring in everything, including the relief from vibration via the CF frame, seat post, and FS, this is the most comfortable and stable bike I've ever had.
Long story short, I recommend riding the bike for a while-- like, weeks or months in various situations-- before you make the decision about swapping the stem. Hoods on a gravel bike just change everything completely. Even with reduced grip strength in my hands, I can operate the brakes to a panic stop, locking the wheels, with my hands completely on the hoods. Ultimately I think my own solution is just a few spacers.
I am finding that I want to be more aero on this bike. It's not like riding my acoustic Raleigh with old-school drop bars, where I'm so damn uncomfortable I just avoid the drops as much as possible. If I get a bit stronger in my core-- or train carefully-- I can get lower, and actually use the drops a bit-- then the center of gravity is lower, and the bike's already outstanding handling becomes truly insane. Dodging potholes or cracks in the road at 25 MPH+ is just a little lean and a flick of the wrist-- it just feels so satisfying. After one week, I still have a lot to learn before deciding what power modes I'm using, and if I need to even add risers at all.
Mentally, when I bought this bike, I did exactly what you are doing, or something very similar: I started studying how to swap to straight bars, or bars with a 40mm rise, or something, before I'd ever ridden it. I was convinced the bars would not work for me.
I was totally wrong.
Thx for the reply and sharing your experience with your bike. Glad to hear the drops helped with your hands.
I do agree about trying it first. Sometimes specs don't give the whole story. And the body can adapt (to a point). My gut feeling is the bike will be fine on shorter rides. If problems crop up, it'll be on three plus hour rides. I just don't want to invest in the bike (mentally and physically) only to be dead ended because I can't adjust something.
If needed, I did find some drop handlebars with risers. And I also noticed the stock stem has a six degree negative rise. I thought it was a zero rise stem. So it can be flipped.
Took the bike out today on the road. Immediately felt the handlebars were too low stock. I flipped the stock stem (60mm, -6°) so it was +6°. Still too low. Found an 80mm, +25° stem in my basement and put it on. Much better! Actually felt pretty comfortable. I'll try it on a distance ride to see how it holds up. Thinking I might want to go a little longer to 100mm but not sure. I've always had an issue with getting handlebar high enough. Probably due to the fact that I'm 6'2" tall with a 31" inseam.
A couple of questions for those in the know.
1. I'm thinking of using a handlebar bag. Problem is the front light is wired into the system. Has anyone found a clean way to remove/bypass the headlight?
2. On top of the headset is a cover that the cables and wires run into. How is that cover removed? Pressed on, screwed on or is there a tab to press?
3. Where in the United States can I purchase the Mini Remote?
Thanks.
Last week the power adapter for the SRAM derailleur stopped working. No power when bike was on. Took to REI and they believe the SRAM power adapter is bad. They also said no stock in US for replacement. They are not 100% sure the power is bad and not the Bosch Connector that converts high battery power to the low voltage for the SRAM derailleur. Until then I have to use SRAM batteries. I will take to parts from my other Grizl and figure out which part is bad then order the replacement.
I was able to swap parts between the two grizl bikes and found out the part that failed was BCC3111 Bosch Component Connector. REI is ordering a replacement. This is the dc-dc converter for the derailleur power.
Hey I am glad that they REI could help you out. Let's us know when your bike is back up and running
Grizl CF9 battery overheated and shut off bike. Bike sat for 1 month and it never had this problem before. Took it to REI they seemed less than enthusiastic about it. REI is more mechanical repair and less electrical. The have not figured out the cause yet. Has anyone here had overheating battery issue with the Bosch Performance Line SX Sprint and the 400wh battery?
Hey when it comes to E bikes its not that simple, you have to have all the right toggles and softwear to just do a diagnostic, Canyon or any bike manufacturer has there owen software on the top of the components that they have installed on the bike, Bike is from Canyon battery and components are from Shimano or other companies, so that where it gets compersome,. Look for a Canyon dealer that actually has the bikes in the store.
Wish you luck to have your bike fixed soon.
Unfortunately, Canyon is strictly DTC. They've contracted with REI to handle repairs, but is REI really equipped to handle the electrical side? Maybe some REI stores, but seriously doubt that all are ready to tackle electrical issues like the OP's.
Seriously looked at the Grizl CF8 ebike but decided against mainly out of concern for exactly this scenario.
Take it to any Bosch e-bike dealer and have them run the diagnostic and update the motor, battery, and controller firmware before you do anything else.
+1 on this, but also, IOU, are you running Flow and did you do the last update?
I don't know if this is related, but what convinced me to update was when the SX started throwing codes and shutting off-- though I don't THINK overheating was the cause, I can't remember for sure. The update not only solved the problem, but gave me an extra 5nm of torque.
Can you describe the conditions under which this happened? Was the motor under sustained heavy load? Just curious. I have noticed, in the past, odd, vague, motor-in-pain friction sounds when I was grinding too hard in too high a gear at low speed, e.g., didn't downshift fast enough before a hill... though I think that went away with the update as well. It may be that I've modified my riding style so that this just never happens now.
I also had an overheating issue with my TSDZ2B (before I blew it up in a completely different way -- we had a very non-standard mount for it) that turned out to be entirely reversible, though I don't know WHAT overheated.
When I dug into it, it seemed like I was lucky. With the particular code the TSDZ threw, it can either mean, 'you overheated just this once, better not do it again' or 'sorry, I am fried/bricked.'
Sorry if any or all of that is OT.
