A tangential question on brake squealing, please:
My SL's brakes normally don't squeal. But if I stop at a beach where the surf's only meters away and stay there for 5+ minutes, they squeal briefly on the way back to the Coast Highway.
Then silence till the next beach stop. Never anything visible on the brakes. Never happens inland.
Q. Why the squeal?
An onshore breeze, the daytime norm here, picks up microscopic seawater droplets and salt crystals as it passes over the breaking surf. Then it might pick up tiny sand grains as it crosses the beach to my brakes.
So which one's the culprit here — water, salt, sand, or some combo? The absence of inland cases stands against blown sand as the sole cause. And the quick resolution once I'm underway most favors water. But the salt could still be a player.
Q. Why the squeal?
An onshore breeze, the norm here during daytime, picks up microscopic seawater droplets and salt crystals as it passes over the breaking surf. Then it might pick up tiny sand grains as it crosses the beach to my brakes.
So which one's the culprit here— water, salt, or sand? The absence of inland cases stands against blown sand, and the quick resultion once I'm underway favors water. But the salt could still be a player.
I think it's the Dihydrogen monoxide. And what's wrong with squeaking a bit. Especially coming back from the beach.
I have no clue Jeremy, but I had 4x stream crossing on a recent ride. Therefore I had something going on with my wheels/hubs, so cleaned them out. the squeak was still there. Hoping it was not my Bottom Bracket! So, not audible in the bike stand prior after my cleaning, I heard it from the rear. It was my brakes! uneven wear caused a ridge. the SRAM Apex brakes suck from the generation I have. I filed off the ridge on the pads and the squeak is gone. So, I am not suggesting that your noise is from the same issue. but sometimes it takes a bit of troubleshooting. Good luck!
Squealing is caused by vibration between the pad and the rotor. It could be mechanical in nature, i.e. worn pad (metal on metal), warped rotor, misaligned caliper, or loose caliper bolts. It can also be caused by contamination on the rotor/pad interface. Sand and grit getting embedded in the pad could do it. So could deposits building up on the rotor and glazing from the heat. This can happen from rust deposits on the rotor surface. Those kind usually clear up after a few stops.
Since your oceanside stops are so short, I'd think that sand is probably the culprit, but rust can also happen very quickly in a corrosive environment near the ocean.
We get a lot of bikes in for tune-ups in the spring, bikes that were left outside in a shed or unheated garage. Snowbirds that keep their bikes at the summer home and return in the spring. You would not believe the corrosion that occurs from being exposed to salt air even though they may be a mile or more from the beach. We go through 3-4 cases of this stuff every season.
As for me, the brakes mostly squeal during raining and become silent after a few stops when the water has evaporated. Obviously, dirty pads squeal on any braking, which is notorious for MTBs.
The "ocean" is a normal thing for Americans as the continent is surrounded by high seas. Fun fact: My observation: Many American travellers to Europe are unaware that the word "sea" even exists! :)
Fun fact: Many American travellers to Europe are unaware that the word "sea" even exists!
Fact, eh? That's a lot of Americans. What percentage have you quizzed on the word "sea"?. I'd be surprised to find a single American who doesn't know it.
But maybe a lot of them temporarily forget it on the way over.
It is enough to watch the traveller's channels on YT :) I even didn't know we had an ocean by Gdańsk :)
Hopeless.
I am aware you as an American think everything American (especially the people) is the best but I have the right to express my opinion. Isn't is called the 1st Amendment in your country?
Of course, I respect your own opinion and only regret you couldn't hear that "ocean" on YT yourself.
Absolutely not. Just think it's not as bad across the board as you apparently do. And time and time again on so little credible evidence.
You were expressing a piece of utter nonsense as a "fun fact" — your words. You're not entitled to your own facts.
YT is not an authoritative source on how many Americans know the word "sea".
So the "fun fact" was the statement that enraged you? Edited.
I'm so sorry you perceive all Americans as geniuses. Talking about my own nation, I would say a great deal of my compatriots are just idiots. Approximately 51% of the Polish voters are.
There you go making stuff up to suit your agenda again. Never said or even implied any such thing, and I certainly don't believe it.
But you know as well as I do that you don't have to be anything close to a genius to know a word as common as "sea".
Done wasting time.on this subject.
When Sebastian sang "Under the Sea" in The Little Mermaid, millions of kids were watching. If they didn't know the word before that movie came out in 1989, there is no doubt every kid in America did after that. When I was a kid back in the 60's and 70's, my Mom made me tuna salad sandwiches out of a can labeled "Chicken of the Sea" and taught me a tongue twister: She sells sea shells by the seashore. It's kind of hard to grow up in America and not know that word.
I'm originally from Jersey and we called the sea - the shore. And now in North Carolina - it's the beach. Me - I head to the ocean, mostly. Can everybody sea that?
